Need Bios for X705UQ REV. 2.2
  • Mihail128
    • Apr 2016
    • 4
    • Bulgary
    Hello, need bios dump for ASUS X705UQ REV. 2.2. Old dump here
    • 21679
    Type the laptop serial number, full name and model etc.
    Please read the forum rules..https://www.badcaps.net/forum/troubl...ore-posting​
    • Mihail128
      • Apr 2016
      • 4
      • Bulgary
      Sorry
      Asus X705UB-BX021 SN: K7N0CV13F187304
      MB: X705UQ REV. 2.2
      Initially it had a dead HDD 1 TB. When installing Windows on a new SSD after the first reboot, it did not turn on by itself. When trying to turn it on, it turned on for a while, but after a few seconds it turned off. After several attempts to turn it on, the device stopped showing that the charger was connected (the LED stopped glowing), while the autostart worked from the charger. When disassembling it turned out that the battery was charging. There are voltages of 3.3V, 5V, 1.8V (main), 1.1V (standby CPU) and 0.9V on the GPU. There are no short circuits of the USB and coils. There are no main powers on the CPU. It responds to the power button when you connect only the battery, if the charger is also connected, the device does not turn off, or rather, 4 seconds of pressing - the LED goes out and immediately lights up again. But the charging LED does not light.​
        • 21679
        Sorry
        MB: X705UQ REV. 2.2
        Seems more like a hardware problem but anyway.. post pictures of the long white barcode stickers on the motherboard
        • Mihail128
          • Apr 2016
          • 4
          • Bulgary
          thank you for your attention.
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
