Alienware Area 51m-R1 bricked
  • Jasonexe
    • Apr 2023
    • 69
    Hi everyone, i got a Alienware Area 51M-R1 that recently stopped working after downgrading the bios from 1.5.0 to 1.3.2. When powering on the laptop with the charger plugged in it does not post, fans don't spin and the keyboard doesn't light up either except the power button logo.
    The logo shows a green light for a few seconds and then goes off for a second and keeps repeating for about 4-5 times. After that i get 2 red flashes followed by 1 blue flash which keeps repeating. This code usually means cpu failure but i can confirm that the cpu works because i tested it on a other system
    After some research i found out that this code can also be caused by a corruped bios/rom flash. After hours of searching online i finally found someone that uploaded the bios/ec files that can be flashed on the IC's by using a external programmer. On my motherboard i found 3 IC's which are the following: W25Q128JVSQ, W25Q80DVSIG, GD25Q80CSIG
    I flashed the 3 files on the IC's and the laptop started working again. I wanted to try to downgrade again but i made a backup of the bios first with my external programmer before doing it but the results ended up the same. When flashing the backup bios i still ended up getting the same symptoms as i mentioned at the beginning. Is this motherboard completely dead now ?
    System Specifications:
    Service Tag: 3W0QMV2
    i9-9900K
    RTX 2060
    2x16GB DDR4 2666
    Kingston KC3000 1TB
    Samsung 970 EVOPlus 2TB
    Firecuda HDD 1TB
  • hoaca388
    Badcaps
    • Jan 2022
    • 12330
    i9-9900K
    RTX 2060
    2x16GB DDR4 2666
    Kingston KC3000 1TB
    Firecuda HDD 1TB
    Alienware Area-51m
    Service Tag: 3W0QMV2​
    • Jasonexe
      • Apr 2023
      • 69
      Originally posted by hoaca388
      Alienware Area-51m
      Hi, thank you for responding to my post. I tried the following file you send me but same symptoms unfortunately.
      • Jasonexe
        • Apr 2023
        • 69
        Alienware Area-51m
        Would it be possible to split the EC file from bios file ?
        • ro.man
          • Mar 2015
          • 16
          Try this, not sure about size, if need 128 - just cut it.
          • Jasonexe
            • Apr 2023
            • 69
            My apologies, i mean for the W25Q80DVSIG IC, not KB9542Q. At this point i’m not even sure if the board is still alive. Today i found out why my programmer was getting really hot. When i connect the clip to the bios IC (W25Q128JVSQ) the chipset gets hot in one specific spot. Which makes me think it’s possibly dead maybe.
            • ro.man
              • Mar 2015
              • 16
              My apologies, i mean for the W25Q80DVSIG IC, not KB9542Q. At this point i'm not even sure if the board is still alive. Today i found out why my programmer was getting really hot. When i connect the clip to the bios IC (W25Q128JVSQ) the chipset gets hot in one specific spot. Which makes me think it's possibly dead maybe.
              Check if PCH gets any power, usually some warming it is fine if it's not burning hot.
              Here is your file..
              • ro.man
                • Mar 2015
                • 16
                Try my file, I had similar issue and machine started to work only from 1.7.xx version. File I used for my job with yours ST and Windows key. Later you can go to 1.5.0 with USB drive.
                • Jasonexe
                  • Apr 2023
                  • 69
                  Thank you for trying to help me, unfortunately i still get the same symptoms after flashing the IC's
                  • Jasonexe
                    • Apr 2023
                    • 69
                    Do you have a bin file with version 1.28.0 for both Winbond IC’s? I ordered a pre-programmed KB9542Q and would need that version to flash on both winbond ic’s.
                    • ro.man
                      • Mar 2015
                      • 16
                      Do you have a bin file with version 1.28.0 for both Winbond IC's? I ordered a pre-programmed KB9542Q and would need that version to flash on both winbond ic's.
                      This board has 4 ROMs + EC
                      Main Bios "UH4" - 16MB
                      Blank chip "UE2" - 1MB
                      Thunderbolt "UT2" - 1MB
                      Video "UG22" - 1MB
                      EC KB9542Q-B "UE5" - 160KB​
                      I don't have that board anymore, so it's extracted main BIOS region and EC fw from 1.28 update. You can take ME region from your original corrupted image and combine them. Just copy DMI and Win key from original ROM. You need to work only with main BIOS, rest chips are not that important for start. And do not use any clips etc - take chips out of the board and flash.
                      Good luck.
                      • Jasonexe
                        • Apr 2023
                        • 69
                        Video "UG22" - 1MB
                        Good luck.
                        Thank you for providing me the files. I’m not familiar with doing these stuff unfortunately.. Is there a guide for this somewhere?
                        • ro.man
                          • Mar 2015
                          • 16
                          Just need to read all possible guides you find... Concentrate on main BIOS UH4 only, do not use clips as you can mostly read with it but not write properly. Flash all 1Mb chips back with taken before firmware and live them alone.
                          I created a main BIOS file from clean 1.7.3 update + your original ME + your DMI and Windows key. I've done exactly the same procedure for one of our customers which bricked the same machine with downgrading to version 1.3.2. I managed to make a working BIOS with lowest version 1.7.3, btw you both have ME version 12.0.93.2331 from latest 1.28 update. From the file bellow you can safely go to 1.50 with USB drive (I've done it myself by customer request) or normally update with latest version. Not sure about version 1.3.2 as didn't try it myself but do not think it is a good idea to go to few years old version - all this mess around thermal and power limits just showing a lack of proper cooling. Check your cooling system, remove fans and clean radiators inside, use a proper paste (not MX4) and do not switch to "High\Best Performance" power profile as it force to boost CPU with no reason all the time - always keep "Normal" or "default" power profile and CPU will boost only when needed.
                          • Bradbeat
                            • Jul 2025
                            • 20
                            • Belgium
                            i just bought this laptop, the file you posted isn't accessible it say "Invalid file".
                            By chance, do you still have it?
                            thank you.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12330
                              thank you.
                              You MUST:
                              • Read BIOS guides, methods, resources and tools
                              • Try the method at BIOS guides, methods, resources and tools before requesting help
                              • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                              • Use search function in case someone already answered your request
                              • Post under a related thread if it exists
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                              • Name your thread with make, full model numbers and request
                              • Provide a BIOS/EC dump if possible
                              • Attach files directly to your post instead of linking to external websites
                              • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                              • Bradbeat
                                • Jul 2025
                                • 20
                                • Belgium
                                You MUST:
                                Thank you for your response, I've already done all that and the topic i post was deleted because another existed (this one i assume) that's why i am here.
                                I asked for this file because in my many attempts to try to rebuild or find a bios for this machine, that's at that step that i am.
                                • ro.man
                                  • Mar 2015
                                  • 16
                                  thank you.
                                  Unfortunately I deleted it a long time ago..
                                  Now I can give you only main BIOS region, so you need to replace it on your taken BIOS image. Edit DMI, Windows Key and replace whole region with HEX editor. Have fun..
                                  • Bradbeat
                                    • Jul 2025
                                    • 20
                                    • Belgium
                                    Hi, Thank you very much for the response, I will try this 👍🏼
                                    could you tell me How i can find the DMI région in a HEX éditor?
                                    thanks again !
                                    • UhOhAlienware
                                      Avid repairer
                                      • Aug 2025
                                      • 9
                                      Hello I also just did the same incorrect thing. I flashed back to 1.12.0 and then thought I could recovery flash to 1.3.2 and Alienware Area51m R1 will not boot. I now see that I am up against issues where the flash back to 1.3.2 would never succeed due to Intel ME firmware (dang).
                                      Can I somehow use these posted BIOS files to recover to 1.7.3? I would like to preserve my Service tag and Windows key if possible. Thanks if can share the edit offset.
                                      I need to hex edit the BIOS file and then desolder the BIOS SPI chip and flash and replace on mobo.
                                      My service tag is BWQ8733
                                      • UhOhAlienware
                                        Avid repairer
                                        • Aug 2025
                                        • 9
                                        Did a little more research and appears related to the CPU microcode. I am going to try and swap to an older CPU as I think the 1.3.2. recovery BIOS flash did take but then CPU is not happy at the moment.
                                        • TechMark1
                                          Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                                          by TechMark1
                                          I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                                          09-21-2025, 03:36 PM
                                        • drux
                                          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                          by drux
                                          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                          These models have AMI/Aptio BIOS.
                                          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                          11-03-2024, 01:18 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Bradbeat
                                          Alienware area 51m R1 Bios avec BiosUtilities LA-G881P Rev : 1.0(A00)
                                          by Bradbeat
                                          I maybe posted on the wrong forum so i post it here, tell me if it's not good :
                                          I would like to flash the bios chip with the latest bios found on dell's website and we'll see what to do next.
                                          I got the RCV file (Alienware_Area-51m_1_28_0.rcv) and extract it with biosUtilities, the result was in this picture
                                          My first questions are: -Is it the BIOS_FV_MAIN.bin tnat i have to put on the chip, because it seems to short?
                                          -Taking into account that there is no ssd nor hdd is it ok to flash a "factory" BIOS?
                                          hope it's clear enough, if you...
                                          07-31-2025, 02:18 PM
