BIOS Dump Request for hp 17-by0015cy please fix
  • MegaYadi
    • Mar 2025
    • 9
    Hello I have a hp that turned on but the screen was black and fans at 100% .... I reprogrammed the bios with a .bin that I found here in the forum now does not turn on .... I have the original dump if you can help me, thanks.
    hp 17 bs0015cy
    serial: 5cg8423ccf
    product: 5ED64UAR
    SPS: L22736-601
    10/17MB
    CS184A
    17 KBL-6L
  • peste
    • 13904
    • ROMANIA
    hp 17 bs0015cy
    serial: 5cg8423ccf
    product: 5ED64UAR
    SPS: L22736-601
    10/17MB
    CS184A
    17 KBL-6L
    you have everything you need at post #2....084C8
    https://www.badcaps.net/forum/troubl...ng#post3330399
    • MegaYadi
      • Mar 2025
      • 9
      I tried with 084C8 this time the charger status led worked but still does not turn on.... I press turn on and it does nothing. with the backup that I attached in this post if it turns on and the fans are at 100% without image.
        • 22241
        084C8 is the right bios. You can try older versions if you want, you can extract them yourself. Try another bios chip as well.
        [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
        [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
        If none of the older ones work it`s a hardware problem
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers šŸ˜€,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
          šŸ”§ Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          šŸ’€ Problem:šŸ˜…
          - Device shows ā€œAdministrator Passwordā€...
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • greelidd
          K6604J Vivobook RTX 4070 BIOS Dump Request
          by greelidd
          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
          09-01-2025, 06:14 PM
        • olfelys
          HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
          by olfelys
          Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
          My board enters jumper recovery mode but no BIOS files are available from HP anymore.
          I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
          Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
          post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
          09-05-2025, 12:38 AM
