HP 15-eh0009LA DAG7HAMB8F0 REV F BIOS Dump
  • superhache
    • Nov 2018
    • 46
    • Argentina
    hello, (sorry about the miss spelling in the title, can you fix it? its dag7hamb8f0)
    laptop turnson screen lightsup but then it powers off and again
    hp 15-eh0009la
    DAG7HAMB8F0 REV F
    PID 310G9LA
    SN 5CD14 80RRS
    RYZEN 7TH SERIES
    with some of the bios i downloaded and try them, got picture saying firmware needs to be updated and after that , same issue
    this is de bios dump that came with de laptop
    thanks
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    hp 15-eh0009la
    DAG7HAMB8F0 REV F
    PID 310G9LA
    SN 5CD14 80RRS
    RYZEN 7TH SERIES
    thanks
    Here is your new file, it's a virgin BIOS from HP with your DMI and Windows Key.
    all donations are welcome,
    • superhache
      • Nov 2018
      • 46
      • Argentina
      hello, sorry for the delay answer, but it didnt work, may be its an igpu error. or may be the other bios dump rewrite the EC bios? any way i dont have tools for nay of those jobs.
      can i ask you how to extract files from hp biosupdate.exe, in another platform, i couldnt do it, is tehere a commans line switch or utilkty that can i use,? i want to learn , i was trying to get the pure 087c5.bin file from that exe file and i couldnt. thanls
      so there is no need to followup with fixing the bios i had to return the laptop. thanks
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • MDSI
        HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
        by MDSI
        I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
        Details:
        Model : HP OMEN 17-an012nf
        Motherboard Part Number : DAG3BAMBAF0 REV : F
        Serial Number (S/N) : 5CD7280D51
        BIOS chip : Winbond W25Q64VSIQ
        Programmer : EZP2023+
        Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
        I already...
        07-28-2025, 07:11 AM
      • grimacelord
        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
        by grimacelord
        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
        Motherboard model number: DA0PAMB46A1 REV: A
        Secondary motherboard model number: 0PAB
        SKU: 685K4UA
        Serial number is: 5CD3223BJP
        Recently reflashed this laptop with latest BIOS and once...
        05-07-2024, 08:06 AM
      • DynaxSC
        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
        by DynaxSC
        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
        11-06-2022, 05:22 PM
