Good day guys... I am looking for back-up bios for LG 15Z950. Status of the laptop now is no display. I will upload my back-up.
LG 15Z950 bios
Tags: None
Try
Attached Files↵
https://www.badcaps.net/donateComment
thanks, but still the same, power on fan spinning but no display, laptop history, bsod. fix by cleaning nvme and ram terminal. working fine. costumer ask to repaste cpu. after repaste i install back cover and that the moment that when i'll go for final testing, display got a problem. check on external monitor still no display, change ram, connect external keyboard if capslock is working but its not working.Comment
thanks, but still the same, power on fan spinning but no display, laptop history, bsod. fix by cleaning nvme and ram terminal. working fine. costumer ask to repaste cpu. after repaste i install back cover and that the moment that when i'll go for final testing, display got a problem. check on external monitor still no display, change ram, connect external keyboard if capslock is working but its not working.↵
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by Chris_standHello,
i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
But the...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have desoldered the bios chip (GigaDevice...-
- Loading...
