HP ZBOOK FURY 16 G11 BIOS UNLOCK
  • reeza_plus
    • Aug 2015
    • 59
    • canada
    MODEL: HP ZBOOK FURY 16 G11
    Hi please help unlock this bios
    SN: 5CG44640QC
  • reeza_plus
    • Aug 2015
    • 59
    • canada
    bios password
    SN: 5CG44640QC
    bump
    • Tech@Lap
      • Aug 2022
      • 21
      • Samoa américaines
      TRY THIS
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Originally posted by Tech@Lap
        TRY THIS
        Not work i sure.
        • imranromi
          • Jan 2015
          • 1290
          • Pakistan
          SN: 5CG44640QC
          Can you send photo Which EC use this board?
          board code if possible.
          NPCXHAxxxx?
          • reeza_plus
            • Aug 2015
            • 59
            • canada
            NPCXHAxxxx?
            Bios you sent still locked.
            NPCT760H
              • 22097
              NPCT760H
              NPCT760H is the TPM chip.
              • reeza_plus
                • Aug 2015
                • 59
                • canada
                i dont see a npc chip in the board
                • peter99
                  • Mar 2025
                  • 24
                  • kenya
                  I have the same problem , I changed the TPM chip (NPCT760H), the password is still there
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 501
                    • somewhere in europe
                    why would you do this?
                    • peter99
                      • Mar 2025
                      • 24
                      • kenya
                      My laptop has password bios
                      • piaggi
                        • Nov 2019
                        • 11
                        • Hungary
                        Hello everyone!
                        I would like to ask for help.
                        Please remove the bios admin pass.
                        sn: 5cg5115nm0
                        productID: 9c586av
                        EC(?): npcx998hbobx
                        I read the chip without desoldreing. (two times, same) Will the progamming work this way?
                          • 22097
                          Originally posted by piaggi
                          Hello everyone!
                          sn: 5cg5115nm0
                          productID: 9c586av
                          EC(?): npcx998hbobx
                          Password is in EC chip, can`t patch the bios.
                          • piaggi
                            • Nov 2019
                            • 11
                            • Hungary
                            Okay, thank You, SMDFlea!
                            What can I do? Should I program the EC chip directly or simply the other memory chip?
                            • reeza_plus
                              • Aug 2015
                              • 59
                              • canada
                              NPCXHAxxxx?
                              NPCX998HB0BX
                              • harounHD
                                need clear me bios for hp zbook fury 17 g7
                                by harounHD
                                serial number CND1273QQ4...
                                10-14-2025, 01:50 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • zlr8r
                                Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                by zlr8r
                                Greetings
                                I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                Serial Number: 5CG3202C16
                                Product #/SKU: 739P0AV
                                CT Number: PRTUE00WBI30YX
                                Description: HP ZBook Firefly 14 inch G10
                                BuildID: 23WWWGAZ602#SABU#DABU
                                Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                MAC address not found.
                                • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                10-28-2025, 01:56 PM
                              • Andrew Bower
                                BIOS Unlock for HP zbook studio x360 g5
                                by Andrew Bower
                                I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                12-04-2024, 05:55 PM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
