Samsung XE310XBA-KC1US bios unlock
  • mac_hal
    • 8
    I have this Samsung Chromebook that has a corporate lock and i cant use it. Can someone remove this lock on the bios file?
    Model: XE310XBA-KC1US, BA98-02032DIG
    Motherboard BA62-01035A REV:1.0 JOAN-15
    S/N: 4WQR9FBR440766K
    Bios file in attachement.
    Thanks in advance.​
  • mac_hal
    • 8
    Anyone?
    • lint4u
      • Nov 2013
      • 125
      • lint4u
      Originally posted by mac_hal
      Anyone?
      Try this one and re install using usb stick
      • mac_hal
        • 8
        Unfortunately it doesn't work 🙁
        • lint4u
          • Nov 2013
          • 125
          • lint4u
          last choise
          • mac_hal
            • 8
            Not working again - after reloading (and the operating system of course) the corporate lock is still present.
            • lint4u
              • Nov 2013
              • 125
              • lint4u
              have you reinstalled the OS using chrome recovery ?
              • mac_hal
                • 8
                Yes
                • minhdigital
                  • Nov 2022
                  • 764
                  • Vietnam
                  Thanks in advance.​
                  Send to you !
                  • mac_hal
                    • 8
                    Originally posted by minhdigital
                    Send to you !
                    Worked! You are awesome!
                    Thank you very much!
                    My thanks to everyone!
                    • yessenia
                      • Aug 2025
                      • 3
                      • Guatemala
                      Hello, can you help me? I have a Samsung with the same specifications that no longer turns on because I tried to switch to a different operating system. I need the file to be able to restore the BIOS. I would appreciate it, thank you very much.
                        • 21841
                        Type the laptop serial number, full name and model, motherboard model, etc.
                        post the contents of the bios chip even if it is corrupted..
                        read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                        • yessenia
                          • Aug 2025
                          • 3
                          • Guatemala
                          Hola, ¿me pueden ayudar? Tengo un Samsung con las mismas especificaciones que ya no enciende porque intenté cambiar a otro sistema operativo. Necesito el archivo para poder restaurar la BIOS. Se lo agradecería, muchas gracias.
                          Modelo: XE310XBA-KC1US, BA98-02032D10,
                          placa base BA62-01035A REV: 1.0 JOAN-15,
                          número de serie: 4WQR9FBR527501N.
                          Hi, can you help me? I have a Samsung with the same specifications that no longer turns on because I tried switching to a different operating system. I need the file so I can restore the BIOS. I'd appreciate it, thank you very much.
                          Model: XE310XBA-KC1US, BA98-02032D10,
                          motherboard BA62-01035A REV: 1.0 JOAN-15,
                          serial number: 4WQR9FBR527501N.
                          in English please...
                          • peste
                            • Dec 2016
                            • 13550
                            • ROMANIA
                            The bios chip must be unsoldered from the board before writing or reading..
                            do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                            solder wires between the programmer and the bios chip..
                            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • Kjell
                              Samsung Series 9 - BIOS issue
                              by Kjell
                              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                              08-01-2025, 09:15 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
