hp 245 g6 bios
  • mhmh91
    • Aug 2018
    • 13
    • colombia
    hp 245 g6 bios
    hello everyone i need bios file for hp 245 g6
    serial: 5cd8400z61
    board name: da00p2mb6d0 rev: d
    model: 0p2
    the original file does not project video or if someone can rebuild it, thank you very much. i will be very attentive
  • hoaca388
    Badcaps
    • Jan 2022
    • 12395
    serial: 5cd8400z61
    model: 0p2
    HP 245 G6 Notebook PC
    • DasChitradeep
      • Aug 2025
      • India
      My laptop: HP 245 G6. Processor: Amd A6 7350b. Motherboard: DA00P2MB6D0 REV D So, I know a very little about bios and all and tried to install a latest bios manually. I downloaded it from the Hp's site (F 40) and flashed it manually. The hp bios screen showed 100% progress and went to a black screen showing "writing bios image" and suddenly the screen went down. My laptop wasn't starting any more and the fan spinning has reduced drastically. Now when i try to boot, nothing comes and I can only hear faded fan spins. I want to know the fix and also where I went wrong.
        • 22080
        Remove all power, adapter,battery, CMOS battery. Press the power button for 30 seconds, attach CMOS ,battery, charger and see if it starts up any differently. If there is no change you will need to make a backup of your bios chip contents and post it here. For that you will need an SPI programmer. https://www.badcaps.net/forum/troubl...rces-and-tools
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • lap-top123
          Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
          by lap-top123
          HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
          Hp Elitebook 850 G8
          ProdID 52W98EC#ABD
          SN# 5CG1458XQ7
          Mac-address #1: 84:14:4D:2C:4B:5B
          UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
          Mainboard : 6050A3216701-MB-A01(A1)
          08-20-2025, 07:28 AM
