HP 15-CS needs DMI and licence after mobo replecament
  • bociub
    • Dec 2023
    • 32
    Hi I have tried, but I failed. An old motherboard died (chipset blown) and I buoght another (and better) one. However, the new motherboard has no identity and windows key. Can someone copy these for me from the old bios into the newone, please? sn: 5CD9215YR9 (belongs to the old motherboard.)
  • hoaca388
    Badcaps
    • Jan 2022
    • 12413
    Your new motherboard is not the HP Pavilion 15-cs1006na with BID 084C0, it has BID 086AA, on the new motherboard the information has been deleted, only the window key remains.
    • bociub
      • Dec 2023
      • 32
      yes, it is a different motherboard. I was worried a bit but it fits perfectly into the case. I bought as 15-CS. The winkey is not present or working in the new bios. I can not activate the windows home, however it worked with the old one.
      • baletak
        Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
        by baletak
        had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
        I have updated laptop model number.
        1) I did not find the way to update laptop serial number - I have this one.
        2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
        Hope to find someone to help me with this as I am hitting dead end at the moment.
        Many thanks
        Miro
        05-23-2025, 01:21 AM
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
