MSI Vector 16 HX A13VHG-280UK
  • Edgars UK
    • Jul 2023
    • 25
    Can you please help me fix the original bios file?
    Laptop won't boot with original bios and no sign of life. From original MSI site download bios and laptop new start but no screen.
    Please help and thanks in advance.
    S/N:K2401N0063285
  • noname2024
    • Aug 2024
    • 291
    • CỎ MỸ XỊN
    Try flash https://www.msi.com/Laptop/Vector-16...r-16-HX-A14VHG
    • Edgars UK
      • Jul 2023
      • 25
      I did flash. Now power on but no screen. I flashed with the programmer. Any other ideas?
      The attached file is my original bios dump.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12278
        Vector 16 HX A13VHG
        https://www.msi.com/Laptop/Vector-16...r-16-HX-A13VHG
        • noname2024
          • Aug 2024
          • 291
          • CỎ MỸ XỊN
          try flash vbios https://www.techpowerup.com/vgabios/267193/267193
          • Edgars UK
            • Jul 2023
            • 25
            Thanks everyone.
            I programmed both the bios and the graphics card bios but nothing changes-it turns on but there is no screen. Maybe someone can take a look and fix the original bios file which is in the attached files. Because the original bios does not turn on.​
            • bondminer009
              Need Bios for Latitude 7650 (No Original / dump bios file)
              by bondminer009
              Good Evening,
              Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
              Thank You
              Salam,
              Three
              11-12-2024, 07:48 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • joshAU
              BIOS file for N550JK (original dump attached)
              by joshAU
              Hi all.
              I'm looking for a BIOS file for an Asus N550JK.
              I have a Asus R552J, which I believe is identical to the Asus N550JK.
              I downloaded the latest BIOS (210) for the R552.
              It is named N550JKAS.210.
              The BIOS file is however only 6mb in size.
              I've read the chip with a CH341A programmer and verified the file.
              That file is actually 8mb in size.
              I'm wanting to remove the BIOS password from this unit.
              It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
              08-09-2022, 08:06 PM
            • adelage
              Merge ECS Z77-H2 bios cap file with original dump
              by adelage
              I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
              03-11-2025, 03:07 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
