Bios bin file for HP 15-EF0875MS
  • EpicFix
    • Aug 2024
    • 43
    • Trinidad & Tobago
    This one came to me with the "Bios update failed" loop. In a rush I honestly forgot the golden rule of making a backup of the bios file before flashing to the chip. I downloaded the bios from HP support, extracted and flashed. Tried both 086FD.bin and 08707.bin. Now the machine shows no signs of life and there is no 3.3V to the bios chip. Other voltages are present 5V and 19V. I've checked the logic board for shorts, none present. Unfortunately I do not have a backup bios file to attach as per the requirements of posting. Any help with this issue will be immensely appreciated.
    MODEL: HP 15-EF0875MS
    SN: 5CD9470CSV
    BOARD: DA0P5EMB6E0 REV E
  • Rebirth
    • Sep 2022
    • 50
    • Myanmar
    Does the machine still power on after you flashed the bios from hp website
    • LBTT1121
      • Nov 2024
      • 484
      • Việt Nam
      SN: 5CD9470CSV
      hi, try and feedback
      • EpicFix
        • Aug 2024
        • 43
        • Trinidad & Tobago
        Unfortunately it does not, and I tried both that were provided by HP through the update softpack
        • EpicFix
          • Aug 2024
          • 43
          • Trinidad & Tobago
          Hi, let me begin by saying thanks. This file worked at least enough to get the machine powered on. After this however it goes through writing 2nd PSP bios data, then 1st PSP bios data.....during the latter of the two the system shuts off at random points. If I restart the machine the process begins again and it loops writing the data again then shutting off before completion. I tried using the USB Bios recovery provided by HP but the machine doesn't boot the drive (even after I turned off secure boot to allow legacy support). The system sees the drive as bootable but I get a blank screen after selecting USB. I've also tried the Windows Key + B to do a bios recovery and that goes back to the 2nd PSP, 1st PSP issue after the recovery is complete.
            • 20695
            try
            • EpicFix
              • Aug 2024
              • 43
              • Trinidad & Tobago
              Hi guys....thanks so much for all your help again. SMDFlea​...I will keep the bios file you sent just in case. I did manage to get the one provided earlier by LBTT1121. I disabled secure boot and it worked like a charm. Maybe I'll try it out sometime in the future if I have any issues......for now I'll go by "If it ain't broke, don't fix it". THANKS AGAIN SO MUCH GUYS! I hope to return the favor sometime (somehow). 😁
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • black0hackers
                Need backup bios file X1 carbon Gen 10 nm-d961 rev 2.0
                by black0hackers
                my bios ic is die. so i want backup file to make bios
                some one have can give me. thank you all
                jyg70/jx4c0
                03-23-2023, 03:34 AM
              • Sebastian Codrean
                BIOS file for ASUS F542UN laptop
                by Sebastian Codrean
                Hello to all of you! I need help with a BIOS file.
                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                02-20-2025, 10:25 AM
              • Fr33man
                BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                by Fr33man
                I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                *Novo button power on
                *Disconnected internal battery...
                09-23-2024, 01:16 PM
