Need bios for Asus ROG Strix Scar 17 G733QS-HG015T
  • AxowFlow
    • May 2022
    • 12
    • France
    I am looking for bios for my ASUS ROG SCAR17-G733QS-HG015T.
    S/N: M6NRKD009554258
    I can only find files in .304 but I can't flash them with my EZP.
    I am missing features like the numeric keypad and a bug with the screen.
    While searching I realized that the bios was flashed with an ASUS ROG SCAR15-G533QR.
    So the bios is not the right one.
    The last person must have changed the motherboard.
    I share the .bin with you, but it is not the right one at all.
    Thank you​
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Thank you​
    Here is your new file, it's a virgin BIOS from ASUS (according to your serial number) with your DMI and Windows key.
    all donations are welcome,
    • noname2024
      • Aug 2024
      • 295
      • CỎ MỸ XỊN
      Thank you​
      G733QS
      • AxowFlow
        • May 2022
        • 12
        • France
        Thanks the bios works perfectly.
        But the ASUS ROG SCAR17-G733QS-HG015T has an RTX 3080 normally, while on the motherboard I have it is an RTX 3070.
        After some research I found the STRIX-G17-G713QR-HG068T which was similar to mine.
        Can you find me the bios in .bin please?
        Thank you very much​
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          You're welcome.
          I still don't understand your issue! Is there any wrong thing in your laptop or the GPU inside your BIOS is different from the one on the motherboard?
          • AxowFlow
            • May 2022
            • 12
            • France
            You're welcome.
            The GPU is different, on the current motherboard there is a RTX 3070.
            While ASUS ROG SCAR17-G733QS-HG015T there is a RTX 3080.
            Not compatible with my current motherboard because the GPU is different compared to the BIOS​
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              So inside BIOS setup you can see the GPU is RTX 3080 but you are sure that the GPU on the motherboard is RTX 3070?
              Can you attach image from the BIOS setup and another clear one for the GPU chip on the motherboard to see the numbers on it.
              • alex11x
                • Jan 2014
                • 7
                • Ukraine
                Hello, can you add my dmi info from ASUS ROG SCAR17-G733QS-HG003T to new bios?
                  • 22151
                  Type and post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                  ​Also, post a picture of the white QR code near the CPU
                  • alex11x
                    • Jan 2014
                    • 7
                    • Ukraine
                    ​M2NRKD01129408D
                      • 22151
                      ​M2NRKD01129408D
                      bios + dmi
                      • alex11x
                        • Jan 2014
                        • 7
                        • Ukraine
                        bios + dmi
                        first bios in thread works, my original stuck in asus logo, your stuck in asus ez flash3 utility
                          • 22151
                          You need an SPI programmer to flash my bios.
                          • alex11x
                            • Jan 2014
                            • 7
                            • Ukraine
                            already, it works abnormal
                            • alex11x
                              • Jan 2014
                              • 7
                              • Ukraine
                                • 22151
                                I used the bios from post 3 which is an F1 Asus service bios, and added your DMI to it. Maybe i didn`t add the DMI correctly or part of the DMI is corrupt ? .
                                  • 22151
                                  Try again
                                  • glovecaps
                                    by glovecaps
                                    11-25-2024, 04:23 PM
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • pirati
                                    by pirati
                                    10-27-2025, 04:20 PM
                                    ASUS ROG Scar III G531GT-AL004 Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG Scar III G531GT-AL004 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar III G531GT-AL004 boardview and Scar III G531GT-AL004 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 09:09 AM
                                    ASUS ROG Scar III G531GT-AL111 Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG Scar III G531GT-AL111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Scar III G531GT-AL111 boardview and Scar III G531GT-AL111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
