Lenovo L14 gen1 BIOS unknown supervisor pwd
  • neluka
    • Dec 2024
    • Poland
    Hi All,
    I have looked through this forum before and found plenty of useful information. My problem unfortunately still persists.
    What I have tried:
    - grounding the pin during startup to get into bios - tried around 50 times as per guideline and video but to no effect.
    I would like to get a dump of this bios to look through it and patch it, but I am unsure which programmer to use and how to connect it. This is a TQFP so soldering is off the table.
    Could you recommend any programmer and link a guide so I can get BIOS dumped?
    Thanks in advance!
  • Stefan Steff
    • Mar 2024
    • 413
    • Romania
    Originally posted by neluka
    Hi All,
    What I have tried:
    Thanks in advance!
    Supervisor password has nothing to do with BIOS chip.
    It's stored in SIO NPCE68XX 256kb.
    This can be read/write with SVOD4 or Vertyanov and looks like this attached dump.
    Good Luck!
    • myhamor
      • Aug 2021
      • 4
      • Ukraine
      Thanks dear, working one.
      • Ghost18_07
        Zakaria
        • Mar 2018
        • 87
        • Algeria
        Good Luck!
        Thanks , works for me with both SVOD4 and Vertyanov .
        For SVOD 4 : you should put SPI speed to 3 Mhz and the battery pluged in to work correctly, the size is 256Kb .
        • Mahesa09
          • Nov 2021
          • 67
          • jakarta
          can you write the steps because i always fail to read via svod4
          • Ghost18_07
            Zakaria
            • Mar 2018
            • 87
            • Algeria
            Well, as i said, the trick is to change the SPI speed to 3hz, and don't remove the battery and the 3V battery, to stop the laptop from turning ON when pluging the adapter. after that you can read and write the EC slowly but garanteed.
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • baaligoga
              Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
              by baaligoga
              Good day, everyone!
              I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
              I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
              05-20-2023, 09:48 AM
            • JDong
              Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU laptop
              by JDong
              There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
              • Laptop Model: Lenovo V15 G4 IRU
              • Issue: Forgotten supervisor password.
              • BIOS Chip: GD25B128E (or GD25B128B
              07-06-2025, 10:18 PM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • gestalt.exe
              Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
              by gestalt.exe
              My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
              Laptop stopped booting entirely.
              I used a CH341A programmer to dump the corrupted 16MB BIOS.
              i then attempted the following:
              1. Downloaded stock BIOS BHCN39WW from Lenovo
              2. Trimmed it to 16MB
              3. Extracted the BIOS region from the corrupted dump
              4. Extracted the BIOS region from the stock 39WW
              5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
              6. Injected back my LDGB / DMI
              Yesterday, 10:38 AM
