Lenovo L14 gen1 BIOS unknown supervisor pwd
  • neluka
    • Dec 2024
    • Poland
    Hi All,
    I have looked through this forum before and found plenty of useful information. My problem unfortunately still persists.
    What I have tried:
    - grounding the pin during startup to get into bios - tried around 50 times as per guideline and video but to no effect.
    I would like to get a dump of this bios to look through it and patch it, but I am unsure which programmer to use and how to connect it. This is a TQFP so soldering is off the table.
    Could you recommend any programmer and link a guide so I can get BIOS dumped?
    Thanks in advance!
  • Stefan Steff
    • Mar 2024
    • 243
    Originally posted by neluka
    Hi All,
    What I have tried:
    Thanks in advance!
    Supervisor password has nothing to do with BIOS chip.
    It's stored in SIO NPCE68XX 256kb.
    This can be read/write with SVOD4 or Vertyanov and looks like this attached dump.
    Good Luck!
    • myhamor
      • Aug 2021
      • Ukraine
      Thanks dear, working one.
      • Ghost18_07
        Zakaria
        • Mar 2018
        • 73
        • Algeria
        Good Luck!
        Thanks , works for me with both SVOD4 and Vertyanov .
        For SVOD 4 : you should put SPI speed to 3 Mhz and the battery pluged in to work correctly, the size is 256Kb .
        • Mahesa09
          • Nov 2021
          • 63
          • jakarta
          can you write the steps because i always fail to read via svod4
          • Ghost18_07
            Zakaria
            • Mar 2018
            • 73
            • Algeria
            Well, as i said, the trick is to change the SPI speed to 3hz, and don't remove the battery and the 3V battery, to stop the laptop from turning ON when pluging the adapter. after that you can read and write the EC slowly but garanteed.
            • baaligoga
              Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
              by baaligoga
              Good day, everyone!
              I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
              I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
              05-20-2023, 09:48 AM
            • JDong
              Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU 831A laptop
              by JDong
              There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
              • Laptop Model: Lenovo V15 G4 IRU
              • Issue: Forgotten supervisor password.
              • BIOS Chip: GD25B128E (or GD25B128B
              07-06-2025, 10:18 PM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • grimacelord
              by grimacelord
              Hello there.
              History:
              03-15-2023, 03:29 PM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              >Read BIOS guides, methods, resources and tools
              Ack
              >Try the method at BIOS guides, methods, resources and tools before requesting help
              Ack
              >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
              01-30-2025, 04:26 AM
