Urgence on hp g62-a10ep EC KB rom
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    I GUYS
    Well im here with a problem , and i would like to know if someone here have or could share dumps for this model stated above for the EC and system bios files , the system bios i can download it from HP but the EC KB rom i can't , so if someone have it , please share .
    thk in advance
  • dj_ricoh
    • 2073
    • uk
    Re: Urgence on hp g62-a10ep
    post a pic of the second chip!
    i know they have the same size same brand
    • loser18
      • Nov 2013
      • 274
      If you me give mobo part number, will look for dump in my comp...
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        pm_I_hpc_s MV_MB_V3
        p/n- 01013y000-575-g
        this have intel p6000cpu with ati dedicated gpu and itexpeak intel , the KB bios is a 256kb rom , and the system rom is a 4mb
        but now more strange indeed , start whenting for option , this board was turning on but shuting off after 10sec. noticed that cheking S0 there was no voltage on any coils . just the main step controler coils 3.3 and 5 . and also charge coil 5v , all the outher when pressed on , 0 volts . so i start for the bios , got stucked (but if was showing sign of charging batery and conecting computer seems rom EC is ok .. so just reflashed system rom , and the same happen , so i start thinking on the KB ITE controler . i swaped it from another board i had in spares , and this KB was getting hot and computer not turning on, so replaced a KB frmo a working board and the KB is no longer getting hot , but now , no led on the dc jack , and also not turning on , and only have 3.3 volts , 5 volts is not present on the SN , only having the LDO and EN_LDO and also pin 17 with 4.8 volts . the LDO have the correct value , even like this , i swaped this SN for a RT (swapable) the same symptom , got 3.3 but no 5 volts , on the on off button also getting 3.3 and drop to 0 when pressing ON button .. so my question is , maybe the first KB swap fucked up EC bios , and now KB cannot EN 5 volts ! or what else is missing ? cheked for short , didnt find any , resistance to ground is ok on the 5 volts line .. so ideas ???
        thk in advance
        • loser18
          • Nov 2013
          • 274
          Could you post schematic???
          Hope You swapped exactly the same KBC...
          Every mobo has different architecure, so hard to say without a schematic, whether KBC enables 5V or regulator itself...
          • loser18
            • Nov 2013
            • 274
            OK....
            I've found this...
            It's a BIN for ITE IT8502E from G62...
            • loser18
              • Nov 2013
              • 274
              I'm on iphone so couldn't check the schematic properly but according to power sequence 3.3 and 5v are generated by TI itself...
              • highpulse
                i hate HP
                • May 2013
                • 1490
                • portugal
                i there , yes its enable frmo beggining , so it should have always 3.3 and 5 . but this board is getting to much erratic , each time im finding more problems and the board is getting worst by the time , and just cheking bios and KB's .. but no more 3.3 and 5 , and now 19 volts line is in short . so must fix all lines now first , and then i'll carry forward.
                let you know later guys
                • fagulhas
                  • Apr 2014
                  • PT
                  Viva,
                  Se a linha dos 19v está em curto, verifica a ficha de entrada ( o ultimo que reparei tinha a ficha em curto).
                  Desliga a ficha e verifica se o curto se mantém. Dá também uma verificação nos mosfet DB19 a DB21.
                  Boa sorte.
                  If the line of 19V is shorted, checks the plug (the last one i repair the plug had shorted).
                  Disconnect the plug and check if the short is maintained. Also gives a check on the mosfet DB19 DB20 DB21.
                  Good luck
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1490
                    • portugal
                    boas fagulhas
                    thk for the tip , but that was the first thing to fix , but it damaged many thing on the 19volts line , and many of the spares i dont have in stock , and due to huge time to receive them , my client is in a hurry and prefer buying a computer with us , so ok for me , and next job .
                    thk anyway
                    • Ahmed.nagh
                      • Aug 2015
                      • 5
                      • mina
                      Thank you very much
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • cr4zychriss
                        by cr4zychriss
                        • Rebrand: PC Specialist
                        11-14-2025, 04:04 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • ngngocson113
                        I need bios asus tp301u ( uma ( vga share))
                        by ngngocson113
                        hi everyone
                        i need bios asus tp301uj ( "uma " vga share)
                        my mainboard doesn't use vga chip and it uses vga together with cpu.
                        I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
                        thanks everyone....
                        09-25-2025, 02:20 AM
