DA00PDMB8E0 REV E bios
  • mhmh91
    • Aug 2018
    • 11
    • colombia
    HI i need this bios
    SN 5CD3363YB3
    MODEL 15-FC0006LA
    MODEL BOARD DA00PDMB8E0 REV E
    • 21002
    Originally posted by mhmh91
    HI i need this bios
    SN 5CD3363YB3
    MODEL 15-FC0006LA
    Post your backup, even if it`s corrupt.
    • mhmh91
      • Aug 2018
      • 11
      • colombia
      This bios has a blocking problem due to non-payment from a company. After a while it shows a screen with a collection company logo and does not allow you to work anymore.
      If you help me by cleaning or rebuilding it I would appreciate it.
      • peste
        • Dec 2016
        • 12868
        • ROMANIA
        bios extracted from HP website update for HP Laptop 15-fc0006la (80M34LA), the laptop has four bios variants, yours is 08B2F..
        DMI +KEYWIND 59000 - 5B03F​
        • mhmh91
          • Aug 2018
          • 11
          • colombia
          thank you . I'm going to program and I'll tell you. I'm really very grateful.
          • mhmh91
            • Aug 2018
            • 11
            • colombia
            FULL NOW WORKING !!
            • Thiago_bcs
              • Jun 2017
              • 5
              • Brasil
              Hello, the IT5570E-128 on this motherboard is broken.
              I need the EC128kb file to burn to a new ITE​
                • 21002
                Post your bios backup and Type as text the laptop serial number. The EC can be extracted from your backup.
                • Thiago_bcs
                  • Jun 2017
                  • 5
                  • Brasil
                  OK, the laptop serial number 5CD3450MKT laptop HP 15-fc00093dx
                  • peste
                    • Dec 2016
                    • 12868
                    • ROMANIA
                    try..
                    • Thiago.bcs
                      • Nov 2023
                      • Brasil
                      try..
                      Thanks brother, it worked perfect
                      • edquintero004
                        • Jun 2019
                        • 12
                        • Colombia
                        Hola a todos, por favor alguien que me pueda colaborar con el archivo bin para el pc HP 15-FC0008la, placa da00pdmb8e0 rev: e, a continuación les comparto el archivo dañado.
                        • m1ch43lzm
                          • Mar 2019
                          • 427
                          • Peru
                          edquintero004
                          Please read Forum rules: https://www.badcaps.net/forum/troubl...before-posting
                          Please post in English, and
                          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on
                          • edquintero004
                            • Jun 2019
                            • 12
                            • Colombia
                            Thank you for the reminder, and I appreciate your assistance in providing the BIN (BIOS) file. The equipment details are as follows:
                            Computer: HP Laptop 15-fc0008la
                            Serial Number: 5CD3384D0Z
                            Motherboard: DA00PDMB8E0 Rev: E
                            Additionally, the chip is a GigaDevice 25LR128ESIG
                            • m1ch43lzm
                              • Mar 2019
                              • 427
                              • Peru
                              Try this one, it's version F.18 from HP website + your serial/win key
                              • edquintero004
                                • Jun 2019
                                • 12
                                • Colombia
                                Hi my friend, I wanted to let you know that it didn’t work. I reprogrammed it using the template you provided, and now it shows the following message: The CMOS checksum is invalid. The CMOS will reset to the default configuration, and the computer will restart. Afterwards, please check the BIOS setup options to see if they change.
                                CMOS Reset (502)
                                ENTER - Restart the computer
                                • m1ch43lzm
                                  • Mar 2019
                                  • 427
                                  • Peru
                                  That's normal when you remove the battery/flash a new BIOS
                                  Press Enter key, laptop should restart, it should work after that
                                  • edquintero004
                                    • Jun 2019
                                    • 12
                                    • Colombia
                                    No, my friend. In fact, I performed that procedure several times (I forgot to mention it in the previous message), but it didn’t work. So I used a USB drive in an attempt to restore it using that method, and now it shows the following message:
                                    BIOS corruption has been detected. BIOS recovery will begin
                                    automatically when you restart your PC.
                                    BIOS recovery will take several minutes.
                                    Do not shut down or remove external power from your PC during the process.
                                    ...I’ve let it restart repeatedly for over two hours, but it still didn’t work
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 427
                                      • Peru
                                      Try extracting the clean BIOS from.HP
                                      F.17 https://ftp.hp.com/pub/softpaq/sp157...0/sp157828.exe
                                      F.17 (I don't know the difference) https://ftp.hp.com/pub/softpaq/sp157...0/sp157479.exe
                                      F.18 https://ftp.hp.com/pub/softpaq/sp160...0/sp160012.exe
                                      Not sure why the HP website lists the BIOS as Intel CPU, when these laptops have AMD CPU
                                      How to extract
                                      https://www.badcaps.net/forum/troubl...-file?t=121948
                                      Try flashing the 08B2F.bin, it will be missing model/serial number/win key
                                      There's 4 BIOS versions, the 08B2F should be the correct one according to your BIOS dump
                                      • m1ch43lzm
                                        • Mar 2019
                                        • 427
                                        • Peru
                                        Clean BIOS from HP, there's 4 versions depending on motherboard/CPU
                                        Laptop model: HP 15-fc0xxx
                                        For 08B2F:
                                        MPMLock 821000-82100F
                                        BIOS version F.17, extracted from sp157828.exe
                                        Check this before flashing [Guide] How to find the right HP bios version to flash
                                        08B2F: Mendocino (Ryzen 7x20U)
                                        08B6B: Mendocino (Unknown, maybe Athlon Gold/Silver 7x20U?)
                                        08B30: Cezanne/Barcelo (Unknown, Ryzen 7x30U?)
                                        08BA5: Cezanne/Barcelo (Unknown, Ryzen 7x30U?)
                                        Added BIOS version F.18, extracted from sp160012.exe
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
