HP 17-CN0037NB BIOS FILE NEED PLS
  • technosonic
    • Mar 2014
    • 14
    • belgium
    HI ALL
    AFTER BIOS UPDATE BLACK SCREEN PLS HELP ME THIS FILE ORIGINAL BACKUP
    Motherboard VLAD10-6050A3261101-MB-A01 (A1)
    HP 17-CN0037NB
    SN: 5CG150046F
  • peste
    • 13747
    • ROMANIA
    Originally posted by technosonic
    HI ALL
    HP 17-CN0037NB
    SN: 5CG150046F
    product number​??
    • technosonic
      • Mar 2014
      • 14
      • belgium
      Originally posted by peste
      product number??
      THANK YOU FOR REPONDS
        • 22109
        Please type and post the product number https://www.badcaps.net/forum/troubl...before-posting
        • technosonic
          • Mar 2014
          • 14
          • belgium
          product number??
          product number: 426Q5EA
          THANKS
          • minhdigital
            • Nov 2022
            • 765
            • Vietnam
            THANKS
            Send to you
            • technosonic
              • Mar 2014
              • 14
              • belgium
              Originally posted by minhdigital
              Send to you
              thank you bro. same problem pc not work I dont no (
              only power light have. no fan no caps key light
              i changed ram same (
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
