ThinkBook 14s G2 ITL need bios file
  • pabloroggeri
    Electronic
    • Apr 2015
    • 90
    • Argentina
    Hi friends
    I need bios file for Lenovo ThinkBook 14s G2 ITL
    Motherboard: LV550 14MB
    203008-2
    448.0LY03.0021
    S/N: PW02RL8K
  • shiyab
    • Sep 2023
    • 1603
    • india
    Originally posted by pabloroggeri
    Hi friends
    203008-2
    448.0LY03.0021
    S/N: PW02RL8K
    need dumb
    • pabloroggeri
      Electronic
      • Apr 2015
      • 90
      • Argentina
      Originally posted by shiyab
      need dumb
      Done. The client tried to update bios through software and now it does not start. A message appears at power-up that says "Self-healing BIOS backup progressing", after that it reboots and says the same thing again in a loop. Above is the copy of my corrupt BIOS
      • shiyab
        • Sep 2023
        • 1603
        • india
        hi try new file
        • pabloroggeri
          Electronic
          • Apr 2015
          • 90
          • Argentina
          hi try new file
          thanks for repairing the file. I try to program the 25R256 memory but I get an error in the programming, the same if I try to save the original backup. I use the TL866II Plus. Do you know if there is any solution? I'm thinking if the solution is to buy new memory and program it​
          • Alxzel
            • Jun 2021
            • 3
            • Panamá
            pabloroggeri try with the other programmer i try with the RT809H and work, i can read and write
            • L.L.
              • Jun 2023
              • 16
              • Argentina
              Hello, I need to clean the region me
              File attached
              Thank you​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12322
              File attached
              Thank you
              You MUST:
              • Read BIOS guides, methods, resources and tools
              • Try the method at BIOS guides, methods, resources and tools before requesting help
              • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              • Use search function in case someone already answered your request
              • Post under a related thread if it exists
              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
              • Name your thread with make, full model numbers and request
              • Provide a BIOS/EC dump if possible
              • Attach files directly to your post instead of linking to external websites
              • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
              • L.L.
                • Jun 2023
                • 16
                • Argentina
                I mentioned that it initially wouldn't boot, so I installed a BIOS that I downloaded from the website. After troubleshooting other issues, it's now taking a while to boot.
                I've already read the guides; it's a job I've done before. But in this case, I couldn't do it with the tools I have.
                Brand: Lenovo
                Model: Thinkbook 14s G2 ITL.
                sn: R913LS8R
                motherboard: LV550 14 MB / 203008-2 / 448.0LY03.0021
                Thanks to anyone who can help me.
                • m1ch43lzm
                  • Mar 2019
                  • 897
                  • Peru
                  If you have the original corrupted BIOS dump it's better, we can extract the original serial/MTM/model name/Win key and insert that to a clean BIOS
                  Try this, clean ME, same BIOS region
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • m1ch43lzm
                    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                    by m1ch43lzm
                    Hi everyone
                    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                    There's also an extra OTP Secu.R...
                    09-06-2025, 05:47 PM
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                  • maanee11
                    Help to get Lenovo BIOS bin file for Thinkpad T560
                    by maanee11
                    Hello Everyone,
                    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                    05-15-2022, 11:59 AM
