Bios XU133
  • orlovartyr
    • Sep 2024
    • 7
    • China
    Bios XU133
    Need a dump or the BIOS itself for this board: XU133_JSL_RI_SODIMM_V3.0_N5095A_0 G+0 JWXH-240311-RTL6221C I-240125010098
    Look at the pictures​
  • peste
    • Dec 2016
    • 12600
    • ROMANIA
    post the original bios of the laptop even if it is corrupted,
    • orlovartyr
      • Sep 2024
      • 7
      • China
      I read data with NeoProgrammer_2.2.0.10, CH341A
      Rename the file, bin won't let me upload it to the forum
        SMDFlea commented
        Editing a comment
        bin file uploads are not supported, post in a zip or rar next time
    • orlovartyr
      • Sep 2024
      • 7
      • China
      bios
      • orlovartyr
        • Sep 2024
        • 7
        • China
        I opened the old BIOS with the AMIBCP program, it says:
        Version %x.%02x.%04x. Copyright (C) %04x AMI
        BIOS Date: 12/07/2023 15:45:56 Ver: XU133JDDR4ZX_D002​
        Search for XU133JDDR4ZX_D002?
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
        • vinaypundith
          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
          by vinaypundith
          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
          So, I'm looking for a BIOS dump for this machine - a 16MB one....
          08-03-2024, 12:32 PM
