Asus g713pv bios
  • blazie151
    • Aug 2016
    • 19
    Asus g713pv bios
    Bios chip is a Winbond 25r256jweq. I have a CH341A programmer and I've already pulled up pin 28 and attached it and pin 9 to 3.3v, and tested the voltages. I have the 1.8v hat for it, as well as a SOP8 clip, but the pins don't reach because the chip is a SMD no lead footprint. I've had 1 person tell me the replacement bios chip that can be had on eBay for $30 is only to remove the password, and that the original would have to be soldered back on afterwards. I'm not 100% comfortable soldering that chip off then on then off then back on again. I was trying to use the SOP8 clip to get a viable Bios dump because I saw on this site that most Asus boards use AMI and are able to get the original passwords if I could get a good dump img. So I have some conflicting information and I'm trying to figure out how to proceed. I also saw some probe clips on Amazon that look like they may be able to touch the pins long enough for a Bios dump, but I don't know which ones to get. Any advice would be appreciated.
    • 20477
    Take a picture of the bios chip on the motherboard
    • blazie151
      • Aug 2016
      • 19
        • 20477
        Try a pogo adapter. You just need to measure the chip and get the right one as there are 2 sizes, 6X5 and 8X6 https://www.aliexpress.com/item/1005001830846980.html
        • Genirezi
          • Jul 2021
          • 6
          • Albania
          Hello! Can someone help me with a bios file? I am getting ACPI_BIOS_ERROR
          Serial RANRKD014197426
            SMDFlea commented
            Editing a comment
            Thread merged.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11415
          • Viet Nam
          G713PV
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • maciek1221
            Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
            by maciek1221
            Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
            Config:
            Model: Asus G512LV-HN235T
            Platforma: G532LWS rev. 1.3
            CPU: intel i7-10870H
            GPU: nVidia Geforce RTX2060/...
            03-07-2024, 07:54 AM
