Problem with my ASUS X51R bios
  • basilv
    • Apr 2014
    Hello to everyone. I have a problem with my ASUS X51R laptop. A few months ago, the system did not open because the CMOS battery is low (?) and asked for the CMOS password. I couldn't find the password and I had to replace the bios battery (took me a few hours). It worked well for the past 2 months.
    Now it says the same thing: CMOS battery low and asks for the password. I finally found the password for the laptop, but after I enter it, it goes straight to the BIOS setup where I have no idea what to do. I thought that after I enter the bios password it will enter Windows, but it enters the BIOS setup.
    Do you have any idea what should I do in the bios setup to make the windows run? Or do I have to change the bios battery again (once every 2 months...)? Thanks a lot!
  • stefanbs
    Stefan
    • Jun 2018
    • 16
    Re: Problem with my ASUS X51R bios
    Place a new RTC battery, enter the BIOS, load BIOS defaults and Exit Saving Settings. If the problem persists the there are faulty components on the motherboard.
    • stefanbs
      Stefan
      • Jun 2018
      • 16
      The other option is to flash the BIOS. If anything goes wrong though, you will need a programmer and skills to take the BIOS chip out, program it and solder it back.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • adnan_u
        ASUS ROG Strix B550-I won't POST and cannot enter bios
        by adnan_u
        Hoping someone can help me? I have the above mentioned motherboard which is currently failing to POST. PC boots up to the ROG logo and remains there with the green QLED lit constantly. Pressing F2 and/or Del keys to enter the bios have no effect. I have tried using Flashback to flash the latest ASUS firmware for this board, this results in an fTPM nv corrupted message and pressing Y or N here restarts the PC putting me back where I started.
        I have managed to dump the winbond (w25q256jw18) bios chip using a CH341A chip reader but haven't attempted a manual reflash...
        02-14-2024, 08:29 PM
