HP Victus 15-fb******
What can you do in this mode ?????↵
https://www.badcaps.net/donateComment
UPDATE!!!!
I got an unlocked bios dump that worked right away, I'm going to share it with you guys, hopefully can help someone with the same issue.
Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
ok done thank you for your repy
hi every body
please help i need victus gaming bios file
Victus gaming HP
15-FB1013dx
MB : DAG3PRMB8D0 REV D
tpn-q279
SN: 5CD3359B48
Original file attachAttached FilesComment
The bios above that I told you to write is from the HP website for your laptop model...it should work then, maybe you made a mistake when writing it...remove the chip from the board before writing it...check the solder joints on the chip...check if the resistors on theDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
The bios above that I told you to write is from the Lenovo website for your laptop model...it should work then, maybe you made a mistake when writing it...remove the chip from the board before writing it...check the solder joints on the chip...check if the resistors on the
hp web site not lenovo
tanks anyway i check again my laptopComment
Hi guys,
HP VICTUS
MODEL= 15-FB0047nm
SERIAL NUMBER= 5CD2390YNG
PRODUCT_ID= 79K40EA#BED
MOTHERBOARD = DAG3PPMB8D0 REV D, MODEL G3PP
All voltages are present, no shortcuts on board.
Original bios (attached) is 16388 kb, (not 16384, dont know if this info is important)
BIOS chip is gigadevice 25LR128ESIG 1.8 V
I think that original bios is corrupted and please if somebody can clear it for me. Thanks in advance !Attached FilesComment
Hi guys,
HP VICTUS
MODEL= 15-FB0047nm
Attached Files↵
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by Yacine007hello dear friends
I recently bought this motherboard and I'm having a lot of problems.
- The Wi-Fi doesn't appear in the Network Card in Device Manager (The Wi-Fi card and the Wi-Fi work fine when I installed the old motherboard)
- The hard drive is missing when i reboot the system and reappears when i reboot again (crtl+alt+del).
- When I tried to do an internal BIOS update it doesn't work it always fails.
Can someone help me update the BIOS or give me a new clean BIOS?
hp Victus 16-e0xxx
SN 5CD2050PSQ
Thank you in advance...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
