Dell Latitude 5430 Bios Password
  • anlsmith
    • Aug 2024
    • 10
    I am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it
  • anlsmith
    • Aug 2024
    • 10
    I think that this may be the correct bios dump
    • hoaca388
      Badcaps
      • Jan 2022
      • 11197
      • Viet Nam
      _Post here : https://www.badcaps.net/forum/troubl...setting-unlock
      _There are invisible benefits to group posting that the poster may not know.
      _File's corruptted.
      • anlsmith
        • Aug 2024
        • 10
        Here are the chipsets
        • anlsmith
          • Aug 2024
          • 10
          When I try to do the dump, I am using neoprogrammer. It is giving me options to read three to four different chipsets. Please help
          • hoaca388
            Badcaps
            • Jan 2022
            • 11197
            • Viet Nam
            Read # 3
            • devp62
              • 52
              Hi Guys I hope some one can correct me and or put me in the right direction. I have a Dell Latitude 5430 admin password locked, i have read both UC2 & UC6 using pogo sticks guessing its something to do with the Dell Safebios, never had an issue with other models so far, with this Latitude 5430, uc6 is marked as a 25Q256JVEN but my programmer Xgecu proT48 will only give data in the dump if read as a 128mb if read as a 256mb it is empty also attached in the zip file, Any suggestions and resetting the me or password would be greatly appreciated.
              Latitude 5430
              st 90L1VQ3
              • peste
                • Dec 2016
                • 12254
                • ROMANIA
                Latitude 5430
                st 90L1VQ3
                you are wrong somewhere ..t48 can read 256...try again to make your settings correct...
                • devp62
                  • 52
                  I have tried this on 3 different pc/laptops and same result, i have downloaded the software several time and on different computers and again same result, do you think i have to remove the chip off the board and read and reprog?, on auto detect forUC2 its detects as 128mb and have to remove tick from check id and it reads the chip if not it will error
                  • devp62
                    • 52
                    laptop does work just locked with password
                    • minhdigital
                      • Nov 2022
                      • 718
                      • Vietnam
                      Pogo sticks not good , you need remove the chip off the board and read and reprog
                      • Stefan Steff
                        • Mar 2024
                        • 224
                        • Romania
                        You're right! ... Especially don't work good with WSON 8x6mm like in this case...
                        • gizaha
                          by gizaha
                          02-13-2024, 07:18 AM
                        • jhanra
                          by jhanra
                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                          11-02-2024, 04:19 AM
                        • TripTop
                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                          by TripTop
                          Hi
                          i have dell latitude E7270 with following symptoms:
                          - takes long time to restart.
                          - sometimes powers on and then off
                          - sometimes while working it just dies,
                          From googling online bios clean could possible resolve this?
                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                          I reinstall...
                          09-09-2024, 02:05 PM
                        • iwu
                          Dell Latitude 5520 - dump bios to obtain password
                          by iwu
                          I am not experienced in electronics, but I really want to check if my idea is possible.
                          I have motherboard replaced from Dell Latitude 5520 (11th gen on i5 CPU).
                          BIOS/UEFI access on that MB/PC is blocked by password which I want to get it know - even if I need some bruteforcing or stupid manual activities.
                          There was no computrace activated.
                          I was happy when I saw many posts about removing BIOS password based on .bin file dummps. I wanted to go little further - get to know the password from the dump.
                          1. I do not know how thebios...
                          04-14-2024, 04:10 AM
                        • Elaid02
                          Dell Latitude 9440 Bios password
                          by Elaid02
                          Hii
                          is it possible to remove bios password for this laptop
                          -- Dell Latitude 9440 --
                          is the bios file size = 64 MB ??
                          06-12-2024, 05:41 AM
