HP Elite x360 830 G10 2-in-1 bios unlock
  • hoaca388
    Badcaps
    • Jan 2022
    • 11807
    Originally posted by PedroHS29
    Hello guys,
    I have a question for you, I need to clear the bios administrator password (the password that you need enter when you try to access to rhe bios settings - F10 press key) I don´t have Bios POST password, i can turn on perfectly the computer and enter to windows because the PC don´t have POST Bios password, this PC only have configure Bios Administrator password to enter to the BIOS setup.
    Then i need to clear this password, i think that this password it´s located in EC ROM chip but it am not sure 100%. In this way, i attached you the two files dump (EC ROM and BIOS CHIP files).
    Can you help me to unlock this PC? And give me the correct steps to do the procedure??
    PC information
    - Model: HP EliteBook x360 830 G10 2-in-1
    - S/N: 5CG4194G2M
    - ProdID: 6V439AV
    Thanks in advance!
    Try
    HP Elite x360 830 13 inch G10 2-in-1 Notebook PC
    CT Number_6MBNN0F81JGK50
    Serial_5CG4194G2M
    Product_6V439AV
    Fearture byte_476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVcAd6eMfPfXguhKhkjhk8mEmVn7nVngpDpVpWpnpqprqMqkqz.N4
    Build Id_23WWWGBZ602#SABE#DABE
    • PedroHS29
      • Jul 2024
      • 7
      • España
      Originally posted by hoaca388
      Try
      Serial_5CG4194G2M
      Product_6V439AV
      Hi hoaca388 ,
      I flash bios ic and ec rom mod that you send me and i solder again both chips in the motherboard and when i try to enter to the bios setup, the pc continue request me the bios administrator password. Nothing change with these files.
      Can you help me?? Something is wrong.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11807
        Hi hoaca388 ,
        No chance to reset to factory settings ?
        • PedroHS29
          • Jul 2024
          • 7
          • España
          No, i can not enter to bios setup in the first boot after flash dump mod files that you send me. When i press F10 key in the first boot continue display to enter bios administrator password again...
          Can you send other files? Or tell me where i can delete the values where is located this password with HEX editor and in what ic, bios chip or ec rom?
          I remenber that in elitebook g7 was located only in ec rom chip this password in line 37000.
          I hope your feedback or help again
          • hoaca388
            Badcaps
            • Jan 2022
            • 11807
            With the G10 series things are not so simple, it will restore from EC.
            • PedroHS29
              • Jul 2024
              • 7
              • España
              #26
              Then, what can I do to remove the bios administrator password to can enter in bios password?
              because with first mod files was not working this method
              Any help more or something to do?
              Thanks in advance!
              • hoaca388
                Badcaps
                • Jan 2022
                • 11807
                #27
                Thanks in advance!
                There is no way at the moment.
                • PedroHS29
                  • Jul 2024
                  • 7
                  • España
                  #28
                  Okay, then we just have to wait and see if someone else knows another way to remove this bios administrator password with other mod files or something like that.
                  Thanks for your help and support!
                  • minhdigital
                    • Nov 2022
                    • 758
                    • Vietnam
                    #29
                    Try !!
                    • PedroHS29
                      • Jul 2024
                      • 7
                      • España
                      #30
                      Originally posted by minhdigital
                      Try !!
                      Hi minhdigital,
                      Occur the same with these files, when i try enter to bios setup, appear the screen where request me the bios administrator password
                      Not working these files, do you have other alternative?
                      Regards.
                      • Yassne_zou
                        • Jul 2022
                        • 16
                        • algeria
                        #31
                        hello
                        can you help me reser the passowrd plz
                        hp elite x360 830 g10 2-in-1
                        SN - 5CG42006J5
                        • volinakis
                          • Jan 2021
                          • 2741
                          • N/A
                          #32
                          Originally posted by Yassne_zou
                          hello
                          SN - 5CG42006J5
                          write only main bios, leave EC as is. At 1st boot press F10 and restore factory defaults and restart. Before write new bios use BCU to get your laptop DMI and after write it use BCU again to write back DMI.
                          • Yassne_zou
                            • Jul 2022
                            • 16
                            • algeria
                            #33
                            Ok i i will try it
                            • Yassne_zou
                              • Jul 2022
                              • 16
                              • algeria
                              #34
                              how get laptop DMI plz
                              • volinakis
                                • Jan 2021
                                • 2741
                                • N/A
                                #35
                                I've told you, use BCU (Bios Configuration Utility) - I am using V4.0 - to get DMI before writing modified bios and after writing new bios which put your laptop in mpm (manufacturing program mode) use BCU to write back DMI. If you don't know how to use BCU search in this forum, i've posted how to use it. You also have a label inside bottom cover with your DMI, you can write those values entering in bios setup and in Main tab you have "Write machine unique data"
                                • Yassne_zou
                                  • Jul 2022
                                  • 16
                                  • algeria
                                  #36
                                  I did not find the program
                                  • Yassne_zou
                                    • Jul 2022
                                    • 16
                                    • algeria
                                    #37
                                    How can use Bios Configuration Utility to ream dmi
                                    • ace.code
                                      • Apr 2016
                                      • 133
                                      • Estonia
                                      #38
                                      tried to unlock but still locked can someone help ?
                                      hp elitebook 830 g10
                                      sn: 5CG4165N35
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post merged
                                    • virusjez
                                      • Jun 2017
                                      • 29
                                      • Philippines
                                      #39
                                      can you help me unlock
                                      SN - 5CG4180ZBW
                                      ProdID:8Q416UP#ABA
                                      • rex98
                                        • Feb 2023
                                        • 1280
                                        • Mandaue CEBU, Philippines
                                        #40
                                        Tested bios unlocked V70, main only flash it would boot to MPM.
                                        you can use this in your HP Elite x360 830 13 inch G10 2-in-1 Notebook PC its already Clearme.
                                        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                        use BCU and put your original DMI.​
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • gsm4all
                                          HP Elite x360 830 G9 2-in-1 bios unlock
                                          by gsm4all
                                          hello, need help with bios unlocking
                                          6050A3316601-MB-A01
                                          2022-01-20
                                          HP Elite x360 G830 G9 2-in-1...
                                          10-07-2023, 07:16 AM
                                        • Andrew Bower
                                          BIOS Unlock for HP zbook studio x360 g5
                                          by Andrew Bower
                                          I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                          That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                          12-04-2024, 05:55 PM
                                        • Syavko1
                                          Unlock Bios HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          by Syavko1
                                          Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? ​
                                          01-22-2025, 02:04 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
