HP 14-dv0002ne
  • ebrahemcs
    • Jun 2020
    • 25
    • united arab emarites
    HP 14-dv0002ne
    This is the first post for me
    it's urgent Plz i need Bios File for my HP laptop 14-dv000ne S/N: 5CD111D7GZ
    • 21986
    Post your bios backup
    • ebrahemcs
      • Jun 2020
      • 25
      the problem is i give it to someone and he try to fix before, i think he write wrong file
      anyway i'll attach the file i already read
      thanks in advance
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        what is the motherboard model?
        • peste
          • 13661
          • ROMANIA
          thanks in advance
          bios extracted from HP website update for HP Pavilion Laptop 14-dv0002ne (2R0N8EA)
          DMI+KEYWIN 500000 - 50103F
          • ebrahemcs
            • Jun 2020
            • 25
            i'll update you ....
            thanks
            • ebrahemcs
              • Jun 2020
              • 25
              i'll try it then update you
              thanks
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • testaccgta
                Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                by testaccgta
                Hi, everyone!
                I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                09-01-2024, 08:24 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
