Acer E5-576G -- how to flash bios with USB?
  • inck243
    • Jul 2024
    • usa
    I downloaded this .bin file. https://www.badcaps.net/filedata/fetch?id=2100703
    so can i put the file on a USB stick and flash it using FN+ESC? Or do I need a bios chip programmer?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    The file you downloaded is complete bios file and needs to programmed with an spi programmer.
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • abhorsen
      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
      by abhorsen
      Hey guys,
      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
      07-06-2023, 10:22 AM
    • survivalbloke
      If I flash this bios file, will it just work, or does it need the ME cleaning?
      by survivalbloke
      I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
      ENVY X360
      15-ew0013dx
      SN: CND2261KS3
      Prod: 698V0UA
      Board: LA-M021P Rev 1A
      Chip# Winbond 25R128JVSN​
      Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
      10-09-2024, 08:40 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
