DELL 3310 PINEHILLS MLK MAIN BOARD 6L 19717-1
  • Gbolahan John o
    • 25
    • Nigeria
    DELL 3310
    PART NO: PINEHILLS MLK MAIN BOARD 6L 19717-1
    SERVICETAG: 6TZZY93
    BIOS TPM COMPLAIN ERROR, PLEASE HELP ME REMOVE TPM COMPLAIN
  • Gbolahan John o
    • 25
    • Nigeria
    Sorry sir, I don't know what is wrong with network. this are my backup file
    • hoaca388
      Badcaps
      • Jan 2022
      • 11883
      Latitude 3310
      Service Tag: 6TZZY93
      • Gbolahan John o
        • 25
        • Nigeria
        Originally posted by hoaca388
        Latitude 3310
        Thank you for you quick response sir. I still have the complain with file you sent for me sir, please help me to cross check sir.
        Alert! TPM device is not detected.
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
