Dell Inspiron 14 5425 bios needed
  • kurobaxkaito
    • Dec 2019
    • 10
    Originally posted by kurobaxkaito
    I'm having the same 2,5 error code, is there any way you can check the BIOS file again to see if there's a problem? I flashed my original BIOS back on and my original BIOS doesn't have any light codes. Only with the 'fixed' BIOS file.
    Model: Inspiron 14, 5425
    Reg Mode: P157G
    Reg Type No: P157G004
    ST: G8G6CS3
    EX: 35339417139
    Thank you, I tried again and same error. Perhaps it's not a BIOS issue afterall?
    • ResoluteHawk
      • Nov 2021
      • 154
      So here is a dump of the chip that works. I can't use it though because it prompts me with a Clear TPM message on every boot, and no matter if I choose Yes or No, the message happens on every boot. The customer will not accept this.
      I need the Windows key, Service Tag, and TPM (if able), from the NotWorkingBIOS file, to be transferred into to the WorkingBIOS file.
      Service Tag should be 7ZPTJS3.
      • ResoluteHawk
        • Nov 2021
        • 154
        Ok I figured out how to transfer the Windows key and Service Tag over to a working BIOS.
        I took the BIOS bin file in Post #43.
        I then opened that file in HxD and searched for the text "DTAG" without quotes to find where the service tag is, then deleted the old Service Tag and pasted my Service Tag in.
        For the Windows key, I searched for the Hex value "010000000000000001000000000000001d000000" without quotes. Same process.
        I then saved and flashed the new BIN file to the chip and resoldered it to the customer's board. Works great but they're going to have to know what their BitLocker key is since I don't know how the TPM can be transferred over or if it can.
        • toptechalex
          • Jun 2025
          I did the same thing (this is my first time doing this) and it worked!! thank you all!
          • nguyenhuuducntu
            • Apr 2025
            • 35
            • Japan
            #85
            can someone please help me? my dell inspiron 14 5425 laptop no display, fan spinning, keyboard light on. Here is the original bios
            Reg Model P157G
            STg: H9G3KS3
            Bios chip: Gigadevice
            25LQ128ESIG
              • 21899
              Reg Model P157G
              STg: H9G3KS3
              25LQ128ESIG
              There`s a working bios at post 43 - https://www.badcaps.net/forum/troubl...26#post3671626
              • testing bios bin finder
                • Jul 2025
                • 3
                • Brunei
                #87
                Hello. Can I have the new and working BIOS for Inspiron 5425 STAG: GSQMJL3?
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  #88
                  Originally posted by testing bios bin finder
                  Hello. I have Inspiron 5425 with STAG:GSQMJL3 needed a new BIOS. Can you help me?
                  what's your issue : clean me , no display password..
                    • Jul 2025
                    • 3
                    • Brunei
                    #89
                    Currenly no display but keyboard lights up. Thank you.
                    • kilburnflyer
                      • Jul 2025
                      Originally posted by hoaca388
                      Inspiron 14 5425
                      Service Tag: JF64DS3
                      Is the .bin file you have uploaded specific to this owner's Service Tag and shouldn't be used on other models that are the same with a different Service Tag?
                      • kilburnflyer
                        • Jul 2025
                        Thanks to all the contributions in the this thread here is what I did for anyone else coming to the thread
                        I can't upload the files here only a new member but what I did was:
                        1. Extracted existing failed BIOS with ASProgrammer
                        2. Got isflash.bin from running the .exe installer on another machine and copying isflash.bin before it is deleted when the installer is abandoned.
                        3. Made a note of the hex and locations of the service tag and the windows key - as mentioned in earlier posts
                        3. Opened isflash.bin and the bad bios in HxD
                        4. Copy as pasted the new bios that was contained in isflash.bin into the bad bios - the offsets of the clean bios from isflash.bin are approx. 001E6A90 to 011E6A80 ( i had to adjust the last line slightly when selecting a block using these numbers)
                        5. Added the service tag and windows keys in the clean bios the widows key has no marker to find it in the the clean bios but I found the whole block is located at 00EAA000 - 00EA030
                        6. Added main battery and CMOS battery back and booted - it powered up and down multiple times and I thought it had failed then it just worked.
                        7. Yellow message at top of the screen saying in maintenance mode with fan on full regardless - FN-X disables this
                        This may all be familiar to BIOS regulars but if you are coming to this cold with a CH341 as a one off job this info might help - Good Luck!
                        • amine23
                          • Apr 2017
                          • 89
                          • Algeria
                          #92
                          Dell inspiron P157G
                          ST: BW7CDL3
                          no display
                          • BOGOSY77
                            • Aug 2018
                            • 55
                            • PITON
                            #93
                            Can you rebuild this bios, kb light no display.
                            My backup is uploaded.
                            Inspiron 14 5425 F5501: 1. 1A
                            Reg Model : P157G
                            Reg type No: P157G004
                            ST: 7547WL3
                            EX: 15546894519
                            Thank you so much.
                            • LBTT1121
                              • Nov 2024
                              • 979
                              • Việt Nam
                              #94
                              Reg Model : P157G
                              ST: 7547WL3
                              EX: 15546894519
                              Thank you so much.
                              try
                              • BOGOSY77
                                • Aug 2018
                                • 55
                                • PITON
                                #95
                                Originally posted by LBTT1121
                                try
                                No power with this bios.
                                Can you add this ST : 7547WL3 On this bios?
                                This one is good but I got another SV tag on it, not mine.
                                Thanks,
                                • TheChief79
                                  • Jun 2024
                                  • 17
                                  Where is the BIOS chip located on this model? Want to extract the current BIOS to get a new one with your help. Laptop has no display, fans spinning, keyboard lights up. BIOS1 chip near RAM?
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    #97
                                    Motherboard reference !
                                      • 21899
                                      Thanks,
                                      HxD Hex Editor - https://mh-nexus.de/en/hxd/
                                      • TheChief79
                                        • Jun 2024
                                        • 17
                                        Reg Model : P157G
                                        ST: 1HBPLL3
                                        EX: 3224377479
                                        Please fix my no diplay issue.
                                        Thank you!
                                        • TheChief79
                                          • Jun 2024
                                          • 17
                                          Reg Model : P157G
                                          ST: 1HBPLL3
                                          EX: 3224377479
                                          Thank you!
                                          BIOS from Post#43 works, also with modified Service Tag, but what about my windows key?
                                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:36 PM
                                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:30 PM
                                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:28 PM
                                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
