Samsung Galaxy Book NP750XED
  • Francisco.s
    • 686
    • Spain
    Hi, need bios for Samsung Galaxy Book NP750XED-KC4ES.
    This board mounts a intel alder lake, and seems that the bios is corrupted.
    I tried two versions of flash image tool 16, and shows some errors and can't open it.
    This are the errors:
    Command Line: X:\MEA\FIT 16.0.15.1531\fit.exe
    INFO : Start decompose 'X:/MEA/samsung.bin' image.
    INFO : MFIT version used to build the image: 16.0.15.1554
    INFO : Generate layout dictionary <xpath, container wrapper>
    INFO : Layout dictionary generated successfully
    ERROR : Decompose 'X:/MEA/samsung.bin' image failed.
    Details: Unknown container path: IfwiRoot/CseRegion/DATA_PARTITION/FITC/MngHwStatusEfsNvar
    Command Line: X:\MEA\FIT 16.0.15.1662\fit.exe
    Details: Data bucket: 'BaseDataBucket'. Error: 'Failed to set RegionOrder to b'53241'. Reason: Wrong group value was set: 53241. Value has too few IDs values or duplicate IDs were set'
    Serial number: KS2B99YT50011KE
  • volinakis
    • Jan 2021
    • 2797
    • N/A
    You have to use the same version of MFIT as bios was built, in your case 16.0.15.1554. You have attached bios cleaned and right version of MFIT.
    • Francisco.s
      • 686
      • Spain
      Thans volinakis, I will test and post results.
      • Francisco.s
        • 686
        • Spain
        Bad news from this Samsung, same problem, it reacts to power button but there is no cpu vcore and no voltage for ram.
        Have no enable signal in pins 10/11 for dram pwm chip (TPS51486RJER)
        First time it recives power with the modified bios, (image.rar) could see some pulses at pin 1 of flash chip. (seems that kbc reads its firmware from bios at that moment)
        Could be that bios region is the one that is corrupted, but can't get a good bios from Samsung or internet.
        I will update when there is some news with it.
          • 21440
          You can get a bios region.Yours is P08CFG ,the latest is P14CFG
          Finding Bios Update Packages
          https://www.badcaps.net/forum/troubl...96#post1832296
          6.1.11. Samsung​
            • 21440
            There are some older bios updates that you can get from the microsoft update catalog. To do this,look for a string of hex in the bios above C.a.p.s.u.l.e.L.o.n.g.M.o.d.e.B.u.f.f.e.r (search for capsulelongmodebuffer in ASCII)
            Click image for larger version  Name:	Capture2.jpg Views:	0 Size:	76.5 KB ID:	3292498
            Select16 bytes after ÁþÄM 82 43 26 D6 7A 3B FB 51 B8 46 F2 48 46 CB 72 3B .Those bytes are a UEFI GUID,and they need converting to a standard GUID
            https://toolslick.com/conversion/data/guid
            convert 82 43 26 D6 7A 3B FB 51 B8 46 F2 48 46 CB 72 3B
            to a standard GUID D6264382-3B7A-51FB-B846-F24846CB723B .You can find this converted GUID in the bios using UEFITool.
            Now you have the GUID go to https://www.catalog.update.microsoft.com and enter the GUID in the search box
            https://www.catalog.update.microsoft...6-F24846CB723B
            Download the CAB file from any of the updates ,extract with 7-zip or winRAR.
            Check the GUID in the inf file to make sure it has the same hardware ID . https://www.badcaps.net/forum/troubl...ardware-id%60s
            Edit: Remove the AMI PFAT CAP header from P**CFG040.CAP using AMI_PFAT_Extract.exe then edit P**CFG040.CAP -- 1_00 -- AMI_PFAT_1_DATA_ALL.bin to the right size.
            • Francisco.s
              • 686
              • Spain
              Thanks SMDFlea, seems not an easy job, but will tray and let you know.
              • volinakis
                • Jan 2021
                • 2797
                • N/A
                it's quite easy, replace ABG with CFG from 1st links.txt of SMDFlea's guide, you'll get "ITEM_20240227_22345_WIN_P14CFG.exe" and in 2nd link paste this after "BIOSUpdateItem" and download bios file will start. Thou, i got an error trying to extract with "find_gz125.exe", bios.fd can't be extracted. Here's the bios update.
                  • 21440
                  I`ve had errors before using drag n drop, since then i use Open instead.This one still had an error message but it did extract everything ok.
                  • Francisco.s
                    • 686
                    • Spain
                    Hi volinakis, thanks for your help.
                    I have just downloaded the same file from Samsung just in case yours were corrupted, and have the same content and same problem when open it with find_gz.21.
                    Seems this file is corrupted or have some anti-unpacking technique.
                    Here is the error it shows:
                    Is it the same error it shows for you?
                    I hope somebody have a trick to overcome this.
                    • volinakis
                      • Jan 2021
                      • 2797
                      • N/A
                      yep, "error writing to file P14CFG040.CAP
                      • volinakis
                        • Jan 2021
                        • 2797
                        • N/A
                        nope, try to open file instead drag&drop.
                        • Francisco.s
                          • 686
                          • Spain
                          It's not my case, I have open the file via open menu.
                          I'm using a win-pe system running in a Vmware virtual machine.
                          Tomorrow I will tray in a real windows 10 machine.
                            • 21440
                            I`m using win 7. Try running find_gz in compatibility mode. If it doesn`t work you can get the updates from microsoft instead. Here`s your bios with the new bios region + DMI.The ME has not been cleaned
                            DMI 5A0094 - 5A203F (Length 1FAC)
                            • Francisco.s
                              • 686
                              • Spain
                              Hi SMDFlea, I have tested in windows 7 but doen't work for mi, even in compatibility mode and 640&480.
                              I have got it running the ITEM_20240227_22345_WIN_P14CFG.exe as is, in win-pe and looking at temp dir. It's a bit tricky because the __Samsung_Update folder is erased in no time.
                              This is what I get:
                              • Francisco.s
                                • 686
                                • Spain
                                I will test your bios and let you know.
                                Thanks.
                                • Francisco.s
                                  • 686
                                  • Spain
                                  I've tested your bios without cleaning the me region, and nothing changes. I'm starting to think that bios is not the problem, but I will clean me region and test it.
                                  I've ordered a new ITE kbc just in case it were damaged.
                                  I hope next week the kbc will be replaced and the laptop working.
                                    • 21440
                                    Is the EC chip a IT5571E
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      Hi, yes it is a IT5571E 128.
                                      I 'm still waiting for the new chip.
                                      Is there any issue with this chip?
                                      • Francisco.s
                                        • 686
                                        • Spain
                                        Hi, a few days ago the IT5571E arrived, and after replaced nothing goes better.
                                        The client doesn't want to wait, so nothing more at this moment.
                                        Thanks to all that helps in this thread.
                                          Samsung Galaxy Book Galaxy Book Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Galaxy Book Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book boardview and Galaxy Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:20 AM
                                          Samsung Galaxy Book Galaxy Book Go LTE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Galaxy Book Go LTE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book Go LTE boardview and Galaxy Book Go LTE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 03:40 AM
                                          Samsung Galaxy Book Pro GALAXY BOOK PRO I5 8GB 15.6IN SLV Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Pro GALAXY BOOK PRO I5 8GB 15.6IN SLV Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GALAXY BOOK PRO I5 8GB 15.6IN SLV boardview and GALAXY BOOK PRO I5 8GB 15.6IN SLV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 02:00 AM
                                          Samsung Galaxy Book Pro 360 Galaxy Book Pro 360 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Pro 360 Galaxy Book Pro 360 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book Pro 360 boardview and Galaxy Book Pro 360 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
