Lenovo Legion PRO 5 16IRX8, i9+RTX4070
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
The vBios is available at Lenovo support - https://pcsupport.lenovo.com/us/en/p...7-265289D96F6F
https://download.lenovo.com/consumer...ios_update.zip
Extract the exe from the zip file ,if the laptop is booting from uma just run the exe. If not then extract using the command line. Make a new folder on your C: drive called TDK ,put the exe into that folder ,run the command as Admin
cd C:\TDK
legion_y9000p_irx8_rtx4070_vbios_update.exe /ext
The rom file Y780-RPL_GN21-X6_Base55W_Max140W_0010_775_2_gsync__95.06.1E.00.98_PP.rom can be padded out with FF`s to whatever the chip size is using a hex editor. What size is the chip ?
I extracted the rom file easily by running "legion_y9000p_irx8_rtx4070_vbios_update" then get it from %temp% folder.
Most of the time when I found a vBIOS posted online, it's always smaller than the chip size by a few bytes. For an example this one is 2000KB (1F4000h) but I think the chip will be 2048KB (200000h). Also when I compare between the 2 files, I found the extra length in the original dump filled by 00`s, maybe the programmer is doing this by itself.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello! Thank you very much for your help! It's probably not the BIOS. Before you did it for me, I tried it myself, but with what I did, it got worse. The keyboard backlight stopped working, after pressing the power button, it lit up for a few seconds, and cyclically went out and lit up. When I flashed your BIOS, the laptop started to start up as before. The keyboard backlight worked, the fans started to spin over time when the cooling heated up. But it doesn't initialize completely. Also, when I tried to find it by the chip marking in the program, I didn't find it. It didn't find the chip automatically, and it didn't find it manually either. I read and flashed it with similar markings. They are both 3 volts.
I have EZP2023 and HC341.
XMC 25RH64CH10
XMC 25QH128CH
Out of Warranty
I have this same laptop and during a Windows Firmware update it got BRICKED. Only thing it does now is the Power Button light comes on and is a white light. Nothing else happens. Have done the power drain and all. I have since found that it might be flash programmed using a CH341A programmer which I have obtained. I see the 2 chips you show in your post but not sure if either or which one is the actual BIOS Chip. Can someone please point me in the right direction. From what I have been reading it should be a chip with WINBOND on it but not finding one on this motherboard. How should I proceed with this? I have downloaded the latest bios file form Lenovo, KWCN50WW.EXE AND HAVE EXTRACETED THE FILES WITHIN. Renamed WinKWCN50WW.fd to KWCN.bin but don't know what chip to flash.
Thanks in Advance for your help.
Sirluke99Comment
Legion Pro 5 16IRX8 - Type 82WK
Out of Warranty
Sirluke99Comment
Legion Pro 5 16IRX8 - Type 82WK - Model 82WK0083US
Serial Number:PF4HK365
Machine Type:82WK
Thanks. Also after closer review the chip on the right labeled U1 U2 is a GigaDevice 25R64ES16.Attached FilesComment
Machine Type:82WK
Attached Files↵
https://www.badcaps.net/donateComment
This specification for the Lenovo Legion Pro 5 16IRX8 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro 5 16IRX8 boardview and Pro 5 16IRX8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 07:12 AM
This specification for the Lenovo Legion Pro 5 16IRX8 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro 5 16IRX8 boardview and Pro 5 16IRX8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 06:40 AM
- Loading...
