Lenovo Legion PRO 5 16IRX8, i9+RTX4070
    Hi masters, anyone can help me with BIOS? Long story short, spilled unit, did not start at all. Found two burned resistors in 3.3/5V step down controler. Now unit start, but it takes 30-40 second to get a picture and than FANs start run at full speed and turn off after 20 seconds, so could be ME corrupted...
    S/N: PF4MN0RM
    Board: NM-F091
    i9-13th + RTX 4070
    Both dumps attached. I tried to clean, but I am not getting picture at all, even after minute.
    There is no boardview and schematic, so would like to try BIOS first, BIOS area has been spilled anyway.
    Thanks for any help.
    hopkok
    S/N: PF4MN0RM
    Board: NM-F091
    i9-13th + RTX 4070
    hopkok
    Legion Pro 5 16IRX8 - Loại 82WK
    Become a Badcaps supporter
    Thanks to all supporters.
      Same issue bro, take 1 minute to get picture, after that FANs at full speed, than goes off. In your files, ME region is cleaned? If so, I have to look for hardware failure.
        Find hardware issues , this is an origin bios.
            Hello! Need help with laptop repair. I am an amateur myself, sometimes I repaired electronics for myself. In general, the laptop is new, on the 13th generation of Intel and graphics 40xx. A drop of liquid leaked through the keyboard, and as I understand it, it rotted away from the microcircuit. I got out my hair dryer to lift the microcircuit and try to solder it, but it does not work. And I can not find such a microcircuit to buy. Can you help? Thank you
              Move the discussion to the main forum..here is the "bios only requests" section...
              https://www.badcaps.net/forum/troubl...mobile-devices
                ok, thanks, sorry. Can you delete?
                  Hello everyone! I soldered the chip, but the laptop does not boot. When I press the button, everything starts working, all voltages rise, the keyboard backlight switches, but there is no image. You can turn it off by long pressing. I tried to make a flash drive with BIOS, but in recovery mode nothing happens, the power light blinks orange, but there are no sound signals. I have a programmer, and I can solder, but the BIOS downloaded from the official site in the unpacked folder weighs 24 megabytes, and besides, there are two BIOS chips on the board. Can someone make two BIOS files? Thanks!
                    Model ?
                    Serial number ?
                    Your dump bios ?
                      Originally posted by hoaca388 View Post
                      Model ?
                      Serial number ?
                      Your dump bios ?
                      Thanks!
                      Legion pro 5 16IRX8
                      S.n. PFAEK1SP
                      I haven't taken the dump yet, I tried but I didn't find a BIOS chip like mine in the list. I had to leave for work for a few days, when I come back I'll try again. I hoped that I could restore the BIOS using a flash drive. Thanks 🙏
                        Model ?
                        Serial number ?
                        Your dump bios ?
                        https://www.dropbox.com/scl/fi/cwcfk...=a7sg84r0&dl=0
                        https://www.dropbox.com/scl/fi/w0cal...=fczo8wkb&dl=0
                        hi! can you make me the dumps I need? thanks!
                          Use Winrar or 7zip before uploading. Do not use external links.
                            Sorry,
                              Sorry,
                              Legion Pro 5 16IRX8
                                Legion Pro 5 16IRX8
                                Hello! Thank you very much for your help! It's probably not the BIOS. Before you did it for me, I tried it myself, but with what I did, it got worse. The keyboard backlight stopped working, after pressing the power button, it lit up for a few seconds, and cyclically went out and lit up. When I flashed your BIOS, the laptop started to start up as before. The keyboard backlight worked, the fans started to spin over time when the cooling heated up. But it doesn't initialize completely. Also, when I tried to find it by the chip marking in the program, I didn't find it. It didn't find the chip automatically, and it didn't find it manually either. I read and flashed it with similar markings. They are both 3 volts.
                                I have EZP2023 and HC341.
                                XMC 25RH64CH10
                                XMC 25QH128CH
