Lenovo Legion PRO 5 16IRX8, i9+RTX4070
  • hopkok
    • Oct 2014
    • 178
    • Slovakia
    Hi masters, anyone can help me with BIOS? Long story short, spilled unit, did not start at all. Found two burned resistors in 3.3/5V step down controler. Now unit start, but it takes 30-40 second to get a picture and than FANs start run at full speed and turn off after 20 seconds, so could be ME corrupted...
    S/N: PF4MN0RM
    Board: NM-F091
    i9-13th + RTX 4070
    Both dumps attached. I tried to clean, but I am not getting picture at all, even after minute.
    There is no boardview and schematic, so would like to try BIOS first, BIOS area has been spilled anyway.
    Thanks for any help.
    hopkok
  • hoaca388
    Badcaps
    • Jan 2022
    • 11885
    S/N: PF4MN0RM
    Board: NM-F091
    i9-13th + RTX 4070
    hopkok
    Legion Pro 5 16IRX8 - Loại 82WK
    • hopkok
      • Oct 2014
      • 178
      • Slovakia
      Same issue bro, take 1 minute to get picture, after that FANs at full speed, than goes off. In your files, ME region is cleaned? If so, I have to look for hardware failure.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11885
        Find hardware issues , this is an origin bios.
        • hopkok
          • Oct 2014
          • 178
          • Slovakia
          • vkobzarev
            • Dec 2020
            • 11
            • ukr
            Hello! Need help with laptop repair. I am an amateur myself, sometimes I repaired electronics for myself. In general, the laptop is new, on the 13th generation of Intel and graphics 40xx. A drop of liquid leaked through the keyboard, and as I understand it, it rotted away from the microcircuit. I got out my hair dryer to lift the microcircuit and try to solder it, but it does not work. And I can not find such a microcircuit to buy. Can you help? Thank you
            • peste
              • Dec 2016
              • 12945
              • ROMANIA
              Move the discussion to the main forum..here is the "bios only requests" section...
              https://www.badcaps.net/forum/troubl...mobile-devices
              • vkobzarev
                • Dec 2020
                • 11
                • ukr
                ok, thanks, sorry. Can you delete?
                • vkobzarev
                  • Dec 2020
                  • 11
                  • ukr
                  Hello everyone! I soldered the chip, but the laptop does not boot. When I press the button, everything starts working, all voltages rise, the keyboard backlight switches, but there is no image. You can turn it off by long pressing. I tried to make a flash drive with BIOS, but in recovery mode nothing happens, the power light blinks orange, but there are no sound signals. I have a programmer, and I can solder, but the BIOS downloaded from the official site in the unpacked folder weighs 24 megabytes, and besides, there are two BIOS chips on the board. Can someone make two BIOS files? Thanks!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11885
                    Model ?
                    Serial number ?
                    Your dump bios ?
                    • vkobzarev
                      • Dec 2020
                      • 11
                      • ukr
                      Originally posted by hoaca388
                      Model ?
                      Serial number ?
                      Your dump bios ?
                      Thanks!
                      Legion pro 5 16IRX8
                      S.n. PFAEK1SP
                      I haven't taken the dump yet, I tried but I didn't find a BIOS chip like mine in the list. I had to leave for work for a few days, when I come back I'll try again. I hoped that I could restore the BIOS using a flash drive. Thanks 🙏
                      • vkobzarev
                        • Dec 2020
                        • 11
                        • ukr
                        Model ?
                        Serial number ?
                        Your dump bios ?
                        https://www.dropbox.com/scl/fi/cwcfk...=a7sg84r0&dl=0
                        https://www.dropbox.com/scl/fi/w0cal...=fczo8wkb&dl=0
                        hi! can you make me the dumps I need? thanks!
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11885
                          Use Winrar or 7zip before uploading. Do not use external links.
                          • vkobzarev
                            • Dec 2020
                            • 11
                            • ukr
                            Sorry,
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11885
                              Sorry,
                              Legion Pro 5 16IRX8
                              • vkobzarev
                                • Dec 2020
                                • 11
                                • ukr
                                Legion Pro 5 16IRX8
                                Hello! Thank you very much for your help! It's probably not the BIOS. Before you did it for me, I tried it myself, but with what I did, it got worse. The keyboard backlight stopped working, after pressing the power button, it lit up for a few seconds, and cyclically went out and lit up. When I flashed your BIOS, the laptop started to start up as before. The keyboard backlight worked, the fans started to spin over time when the cooling heated up. But it doesn't initialize completely. Also, when I tried to find it by the chip marking in the program, I didn't find it. It didn't find the chip automatically, and it didn't find it manually either. I read and flashed it with similar markings. They are both 3 volts.
                                I have EZP2023 and HC341.
                                XMC 25RH64CH10
                                XMC 25QH128CH
                                • 417 namless
                                  • May 2025
                                  • 5
                                  • NEVADA
                                  I'm currently working on a Lenovo Legion Pro 5 16IRX8 laptop with the following specs:
                                  • CPU: Intel® Core™ i7-13700HX
                                  • GPU: NVIDIA® RTX 4070 8GB
                                  • Model: Legion Pro 5 16IRX8 (2023)
                                  • Serial Number: PF4HNG68
                                  I've attached a BIOS image download to Telegram + extracted from the motherboard ( i lost GPU bios extracted to motherboard). I need your help to Make a clean BIOS dump
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                • hardware1
                                  • Sep 2021
                                  • 2939
                                  • N/A
                                  What is the issue of your laptop and why did you lose the vBIOS (GPU firmware)?
                                  all donations are welcome,
                                    • 21164
                                    The vBios is available at Lenovo support - https://pcsupport.lenovo.com/us/en/p...7-265289D96F6F
                                    https://download.lenovo.com/consumer...ios_update.zip
                                    Extract the exe from the zip file ,if the laptop is booting from uma just run the exe. If not then extract using the command line. Make a new folder on your C: drive called TDK ,put the exe into that folder ,run the command as Admin
                                    cd C:\TDK
                                    legion_y9000p_irx8_rtx4070_vbios_update.exe /ext
                                    The rom file Y780-RPL_GN21-X6_Base55W_Max140W_0010_775_2_gsync__95.06.1E.00.98_PP.rom can be padded out with FF`s to whatever the chip size is using a hex editor. What size is the chip ?
                                    Edit: It should be padded with zero`s 00 .
                                    • 417 namless
                                      • May 2025
                                      • 5
                                      • NEVADA
                                      The laptop powers on briefly and then shuts down.
                                      After checking all voltages on the motherboard and confirming they were fine, I suspected a BIOS issue.
                                      Unfortunately, during the BIOS read process, I mistakenly clicked "Erase" and ended up overwriting the GPU BIOS.
                                        Lenovo Legion Pro 5 16IRX8 Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Pro 5 16IRX8 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro 5 16IRX8 boardview and Pro 5 16IRX8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 07:12 AM
                                        09-07-2024, 06:40 AM
