HP Elitebook 255 G9 No OS inject win key
  • dr.thodt
    • Apr 2016
    • 84
    • Netherlands
    Please notify me if this question is not appropriate.
    I bought, totally on purpose a HP Elitebook 255 G9 with no OS. I do have a few Windows licence keys lying around and wanted to adventure a key into this bios.
    What I do know:
    A Windows licence follows this same sting of hex numbers in every bios: 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
    The dump of the HP 255 G9 does not have this string.
    My guess is that Windows activation looks for named string and checks the licence key behind it. (please correct me if I'm wrong, I'm learning).
    The bioses I checked with uefi tool did have the key in the BIOS region in the third padding.
    The bios of the HP 255 G9 seems to have the complete BIOS region in the root. There's no ME region and no discriptor region. Only what looks like the content of the BIOS region.
    I calculated the start offset of the third padding in my bios and injected the hex code followed by the licence key i want in it. I did overwrite the 0xFFs rather than inserting the codes and shifting the rest. So everything after this is still on the same offset and the file still has the same size.
    The laptop warned me of a crc error in the cmos. This did not surprise me. After installing windows and rebooting where necessary this warning did not return.
    It didn't surprise me either that the laptop did not find the licence key in the bios. It was more experimenting than knowledge.
    Still I'd like to know whether it is possible to inject a key into a bios that does not hold one, how to calculate the place where that should be done in stead of guesses, and most of all if I'm allowed to ask for help on this subject here.
    For reference I embedded the vanilla bios of the laptop. In my modded bios I injected the code on offset 0x700000, which by my calculation is the start of the third padding.
    I do not expect serial numbers et cetera are needed for this question, but if they're required I do have them.
  • Guest
    Elitebook 850 G5 BIOS bricked
    by Guest
    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
    I assume the BIOS update failed, so I searched for the BIOS chip.
    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
    Can the corrupted...
    03-24-2025, 01:21 AM
  • Lexsmash85
    Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
    by Lexsmash85
    Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
    Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
    USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
    08-06-2025, 03:41 AM
    by Vesko356
    08-11-2023, 03:27 AM
  • lap-top123
    Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
    by lap-top123
    HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
    Hp Elitebook 850 G8
    ProdID 52W98EC#ABD
    SN# 5CG1458XQ7
    Mac-address #1: 84:14:4D:2C:4B:5B
    UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
    Mainboard : 6050A3216701-MB-A01(A1)
    08-20-2025, 07:28 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
