hp elitebook 835 G10 Bios
  • AkiKawasaki
    • Oct 2024
    • 4
    • Austria
    No This one is a Elitebook 835 G10. I sent you Picture of SN.
    • rex98
      • Feb 2023
      • 1240
      • Mandaue CEBU, Philippines
      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
      use BCU. you can permanently disable Absolute lock in BCU.
      here's your DMI:
      Serial Number: 5CD347DY3H
      Product #/SKU: 8R1M9EC#ABD
      CT Number: PRVNR058JIU3UI
      Description: HP EliteBook 640 14 inch G10
      BuildID: 23WWKRBZ602#SABD#DABD
      Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPguhKhkjhk8mEmVn7nVpDpTpnpqprqMqz.Ag
      • AkiKawasaki
        • Oct 2024
        • 4
        • Austria
        rex98 what is BCU?
        • bartek
          • Sep 2017
          • 15
          • Polska
          Hello friends
          Can someone Clear this bios file for me ?
          serialnumber: 5CG3492Y2D
          productid: 709Y7AV
          Thanks for help very much ​
          • rex98
            • Feb 2023
            • 1240
            Originally posted by bartek
            Hello friends
            productid: 709Y7AV
            here's your DMI:
            Serial Number: 5CG3492Y2D
            Product #/SKU: 709Y7AV
            CT Number: PRVYR00WBIV0JG
            Description: HP EliteBook 835 13 inch G10
            BuildID: 23WWLOBZ601#SABH#DABH
            Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAfPgSguhKjhk8mEn7nWngpDpnpqprqMqkqz.dq
            MAC Address : 60:6D:3C:FC:F9:04​
            • bartek
              • Sep 2017
              • 15
              • Polska
              #26
              here's your DMI:
              sorry my frend but dosent work i have first turn on and i have password
              but if i programing bios i have failure error
              • rex98
                • Feb 2023
                • 1240
                #27
                try this new one same procedure
                • bartek
                  • Sep 2017
                  • 15
                  • Polska
                  #28
                  Thans you so much bios its clear thanks one mkre time
                  • bartek
                    • Sep 2017
                    • 15
                    • Polska
                    #29
                    [QUOTE=bartek;n3579142]
                    I actualization bios on windows and i have this comunicate ?how i can disable this ?
                    and if i turn on caps losc light 5 times after started
                    • bartek
                      • Sep 2017
                      • 15
                      • Polska
                      #30
                      here's your DMI:
                      I write all information about you but i cant turn off manufacturing mode
                      • rex98
                        • Feb 2023
                        • 1240
                        #31
                        put this info in BCU
                        Cirrus Discrete Amp Calibration Data
                        3000000002000000536B0601D3350B00C08BDF3A4EF2D90117013728536C0601D3350B003044513C4EF2D9011701C428
                        • bartek
                          • Sep 2017
                          • 15
                          • Polska
                          #32
                          thanks so much all good all work
                          • SDenis
                            • Dec 2012
                            • 3
                            • Belarus
                            #33
                            Hello friends.
                            I tried two tools for removing the BIOS password, but nothing happened If you can help please with this problem.
                            Thank you!
                            Hp Elitebook 835 G10
                            Serial number : 5CG35037L8
                            ProdID 709Z0AV​
                            • STKR123
                              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                              by STKR123
                              Greetings badcaps community,
                              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                              I learned that desoldering...
                              10-29-2024, 06:03 AM
                            • Guest
                              Elitebook 850 G5 BIOS bricked
                              by Guest
                              I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                              I assume the BIOS update failed, so I searched for the BIOS chip.
                              I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                              However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                              Can the corrupted...
                              03-24-2025, 01:21 AM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • Wahaz
                              by Wahaz
                              10-30-2023, 08:42 PM
