HP 14-dq0055dx - BIOS problem - "Pending Image Being Cleared" Loop
This topic has been answered.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Yes, all the steps have been taken before posting here.
    I'm still not convinced with replacing the EC as i've programmed it.
    Will go for it as a matter of last resort. However, will prefer to wait for others opinion.
    • devonoved
      • Sep 2021
      • jamaica
      Been trying to get past this Error for days now, grimacelord solution saved me a mainboard replacement, put in different RAM and the Firmware recovered successfully.
      • Focus2005
        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
        by Focus2005
        Hello everyone.
        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
        05-01-2025, 05:41 AM
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Timeeez
        X270 - Bios flashing help
        by Timeeez
        I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
        Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
        11-30-2022, 05:17 PM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
