X395
  • parahandler
    • Oct 2023
    • 5
    X395
    Hello! I've had a bit of an issue with my X395, I think during a BIOS update recently, something interupted it; I'm not sure exactly what but it no longer posts.
    - Powers on
    - Power light/Charging lights
    - CPU heats up, fans whir up
    - Black Screen
    - No sign of life.
    I've done the LCD test, so I know the display functions.
    I feel the BIOS is somehow in a corrupt state, I'm not looking for a PW removal or anything like that, but rather how a path in which to install a working BIOS. I have the CH341A to dump/write, so I've attached a copy of my broken BIOS. I can't seem to get a copy of the BIOS to reflash it, as any attempt to get a clean ROM from the Lenovo packages yields an Fl1 file, which I'm sure are some sort of wrapper/compressed/part file so aren't any use.
    Any advice would be much appreciated.
    Thanks!
    - P
    • 22001
    Post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
    • parahandler
      • Oct 2023
      • 5
      Originally posted by SMDFlea
      My apologies; SN: PC1J8942
      • parahandler
        • Oct 2023
        • 5
        I actually ended up resolving this, what I did was as follows:
        - Acquired a copy of r13uj56w.exe, which is the 1.30 version BIOS for the X395.
        - Using innoextract.exe, extracted the contents.
        - Located $0AR1300.FL1 within the contents of that file.
        - Opened it up in a Hex editor (I used HxD)
        - Opened another ROM in the same hex editor, and had a look at the start and the end of the file.
        Start:
Name:	Screenshot 2024-04-29 at 08.42.42.png
        End:
Name:	Screenshot 2024-04-29 at 08.42.35.png
        - Found the above within the FL1 file, and extracted highlighted it all, and then "File > Save Selection", saved it as ROM-extracted.bin (see attached)
        - Then I ran that ROM through the autopatcher v0.2, which generated ROM-extracted_PATCHED.bin (see attached).
        - I flashed the patched image using a CH341A programmer
        - Plugged the laptop in with it's power adapter (keeping the CMOS battery, and main battery unplugged), and taped down the anti-tamper switch.
        - Powered it up, entered the BIOS prompt, which asked for a password: "password 1234" without quotations.
        - Followed the guide for the autopatcher, any character for hardware ID, press space when prompted, and then turned the laptop off when it said "power off".
        - Unplugged the laptop, flipped it back overand used the CH341A programmer to flash the ROM-extracted.bin
        - Plugging the CMOS battery back in, and the main battery, I plugged the adapter back in and powered it on.
        - It kicked the CMOS self heal into life which ran, then it rebooted, and the BIOS was the accessible without a password, still with the CRC error.
        - Entered the BIOS, enabled restore defaults, pressed F9 to restore them all, and then saved and quit.
        - Voila
        I hope this helps someone.
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
          by Vesko356
          08-11-2023, 03:27 AM
        • Caimano
          Need to copy DMI info for HP ProBook 650 G2 Bios
          by Caimano
          UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
          Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
          01-03-2024, 05:19 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
