Hi., I am working on this motherboard MB:marshmallow mb 15257-2n 448.07N06 . 002N ... The required voltages (3.3v, 5V) are ok but the pressing the ON/OFF button does not turn on the laptop. I just noticed that someone messed up with the BIOS. Anyway I was able to read the BIOS, uploaded it. Kindly if some can re-build the BIN files, Model Hp ENVY x360 15-aq100nx , Serial # 8CG710266V, thanks in advance.
marshmallow mb 15257-2n 448.07N06.002N bios
https://www.badcaps.net/forum/troubl...26#post1622426
7.2.4. HP
Your BID is BID081AD ,that bios has been posted on the forum quite a few times before,you`ll find a virgin using the forum search, or use the guides to extract your own.
Learning some basic hex editing is essential these days if you want to learn bios repair.Your bios vendor is insyde.Almost every insyde bios has the serial number and all other DMI info in plain text that can easily be copied from the backup to the new virgin bios.
Searching for the serial number 8CG710266V i found the DMI at starting address 220000 .The full block (area) to copy is 220000 - 22103F . -
Hi help me bioos bin file
Marshmellow_MB
15257-1. My backup fileComment
Every donation made will go towards server fees and maintenance costs.Comment
DMI +KEYWIN 220000 - 22103FDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
