Hp Sure Start Recovery boot loop on HP Elitebook 840 G5
  • viking6791
    • Aug 2018
    • 42
    • My Desk
    HP Elitebook 840 G5
    ProID 2FA66AV
    Build ID 17WWCSAT601
    Has anyone faced such a situation in the past with laptops that have integrated HP Sure Protect.
    I tried to disable it from the bios but I don't have access, to rewrite the bios with a USB disk, it also doesn't work to enter the test menu with the F2 key, the same thing.
    I found a video clip on YT where the person in question edits the bios file saved from an HP 450 G7, but I don't understand most of the explanations because they are in Arabic.
    Can someone help me with some information?
    • 20892
    Serial number
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • viking6791
      • Aug 2018
      • 42
      • My Desk
      I'm sorry, I hope that now I will write all the information.
      HP Elitebook 840 G5
      ProID 2FA66AV
      Build ID 17WWCSAT601​
      SN 5CG82334TL
      Feature Byte: 3X 76j6S6b7B7H7M7Q7W7m7saBaEapaqauawbUdpdqgdhKhk.h4
      CT: PGWHQ00WBAQ1E2
      Mainboard model: COMPUTRO-6050A2945601-MB-A01(A1)
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        HP Elitebook 840 G5
        ProID 2FA66AV
        SN 5CG82334TL
        CT: PGWHQ00WBAQ1E2
        post bios backup
        • viking6791
          • Aug 2018
          • 42
          • My Desk
          This is my bios backup.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11735
            HP Elitebook 840 G5
            ProID 2FA66AV
            SN 5CG82334TL
            CT: PGWHQ00WBAQ1E2
            HP EliteBook 840 G3
            • viking6791
              • Aug 2018
              • 42
              • My Desk
              Originally posted by hoaca388
              HP EliteBook 840 G3
              Thank you.
              It is almost the same, I did not write it in the SPI memory because I will try to modify certain portions of the memory until this message disappears and in addition it is for another platform (mine is Q78).
              Maybe someone has a solution! 🤔
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                Thank you.
                change your laptop hdd/ssd/nvme m.2 whatever you have in the laptop and check again the status is change or not ?
                • NolesFan
                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                  by NolesFan
                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                  10-24-2024, 06:36 PM
                • Takeatry
                  Yet another Samsung QLED Boot Loop
                  by Takeatry
                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                  10-04-2024, 02:57 PM
                • blaster_
                  Samsung UE49MU6105K - boot loop, horizontal lines
                  by blaster_
                  Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                  Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                  06-22-2022, 05:19 PM
                • torchzack
                  Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                  by torchzack
                  Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                  I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                  Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                  08-28-2023, 07:42 AM
                • No Lan
                  [Macbook pro A1708] [Boot loop] [Trackpad ?]
                  by No Lan
                  Hey everyone,
                  Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                  Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                  Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                  05-24-2025, 03:09 PM
