HP EliteBook 835 G7 Bios Request
  • max_sneka2
    • Mar 2022
    • 86
    • iraq
    • Electronics
    Good evening Everyone
    I need Bios Bin File For Hp elitebook 835 G7
    Board Number LINDEN 6050A3147201-MB-A01 (A1)
    Here is Old Bios File
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    • Gadget & motorcycle addicted
    Read the rules before posting
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Become a Badcaps supporter
    Thanks to all supporters.
    • max_sneka2
      • Mar 2022
      • 86
      • iraq
      • Electronics
      You MUST:
      Bios Issue . Black Screen . Turned Off after failed update of bios
      S.N 5CG0330FLM
      • barbarian2009
        • Nov 2022
        • 6
        • Ukraine
        Board Number: LINDEN 6050A3147201-MB-A01 (A1)
        ProdID: 8RN38AV
        SN# 5CG1271K42
        Build ID: 20WWLDDT601#SAK8#DAK8
        I tried to remove the password, read BIOS with CH341A (3.3V fix) programmer. BIOS was read in NeoProgrammer 2.2.0.10. Dump data was read and checked 4 times (compared in HxD). Deleted data area 37000 to 37820 via Hxd. Flashing. At power on, the power LED is on and caps lock flickers 7 times. Flashed back dump BIOS and still the laptop does not turn on. I think the dump is corrupted. Please see how bad it is. (Pardon my English)
        • barbarian2009
          barbarian2009 commented
          Editing a comment
          Originally posted by danito
          try
          Thank you. I tried that but it didn't work. At first it tried to turn on (even the fan was spinning) but then caps lock started flickering again and won't turn on.
      • danito
        • Jun 2016
        • 1729
        ProdID: 8RN38AV
        SN# 5CG1271K42
        try
        • barbarian2009
          • Nov 2022
          • 6
          • Ukraine
          try
          Deleted the first byte from your file and the laptop turned on. Thank you.
          • barbarian2009
            • Nov 2022
            • 6
            • Ukraine
            That didn't fix the problem. Now the notebook does not turn on the first time. It says: Final step of BIOS update. Then it reboots and flickers caps lock 7 times. Several times I managed to boot into Windows and flash SN, PCID, CTNumber, FeatureByte, BuildID via BCU. If you turn off and disconnect the RTC battery for a while and then reconnect it again, it may turn on. Is this a problem with the firmware in the second chip?
            • barbarian2009
              • Nov 2022
              • 6
              • Ukraine
              Finally solved the problem.
              What I did:
              1. Completely cleaned the second BIOS chip. And soldered it in place (without writing anything into it)
              2. In the main BIOS chip flashed the files that threw “danito” (In them BIOS built from the update on the official site HP).
              3. Main BIOS chip soldered on the board.
              4. Check the soldering! Everything is soldered.
              5. Via BIOS Configuration Utility flash SN, PCID, CTNumber, FeatureByte, BuildID
              Done. No more passwords and no more Security Endpoint controller Problem errors.
              • spawnx212484
                • Jan 2017
                • 11
                • france
                S.N 5CG0330FLM
                Hi, have you found a solution? I've had two PCs in a week with corrupted bios...
                • batuhanca
                  • Jun 2019
                  • 14
                  • türkiye
                  If you want, try these as well.
                  • spawnx212484
                    • Jan 2017
                    • 11
                    • france
                    Perfect, it works, but when the computer starts up I get "manufacturing programming mode", is that a problem? don't I have info to recover from the dead bios?
                    • danish8717
                      • Dec 2021
                      • 28
                      • united arab emirates
                      hp 835 g7
                      serial no 5CG11551MC
                      sound not working
                      • tcccorp
                        • Jan 2025
                        • France
                        hello,
                        I read there is 2 flashs on this laptop but I'm just able to find one, near nvme ssd. Could you say me where is the second one ?
                        thanks
                        • peste
                          • 15367
                          • ROMANIA
                          Originally posted by tcccorp
                          hello,
                          thanks
                          search both sides..
                          If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                          It only takes 1 minute:
                          https://www.badcaps.net/settings/subscriptions
                          • tcccorp
                            • Jan 2025
                            • France
                            hello Peste,
                            Thanks, i checked other side and i found another flash, TPM and security chip !
                            • sergg_zp
                              • Apr 2025
                              • Ukraine
                              HI,
                              HP Eleitebook 835 G7
                              Part Number - 8RN39AV
                              Serial Number - 5CG1204DYT
                              Caps lock blinking 7 times. Please help.
                            • jey107
                              • Nov 2025
                              • 10
                              • Switzerland
                              Hi there, im new to badcaps. badcaps is a good website with a great contributors. made a small donation and will keep doing it in future.
                              someone please help me with the followings:
                              1. I need a new bios
                              2. I tried to read the laptop identification numbers via UEFI Tool. but it was giving me a error message. "invalid volume". what would be the best way to read IDs from bad bios ?
                              HP EliteBook 835 G7
                              ProdID: 8RN40AV
                              SN# 5CG0474XBK
                              Issue : blinking orange and white lights, Black Screen . Turned Off after failed update of bios
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                            • AHSAN TARIQ
                              • Jan 2025
                              • 92
                              • Pakistan
                              HP EliteBook 835 G7
                              ProdID: 8RN40AV
                              SN# 5CG0474XBK
                              bro send boardcode
                              • jey107
                                • Nov 2025
                                • 10
                                • Switzerland
                                Originally posted by AHSAN TARIQ
                                bro send boardcode
                                HI, thanks You mean the motherboard ID ? laptop at workplace, will update tomm.
                                • AHSAN TARIQ
                                  • Jan 2025
                                  • 92
                                  • Pakistan
                                  ok
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • wrinex
                                    bios request/fixing dump HP elitebook 840 G6
                                    by wrinex
                                    Hi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
                                    i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...
                                    04-09-2026, 12:39 PM
                                  • Wutru
                                    HP Elitebook 820 G4 BIOS repair assistance required
                                    by Wutru
                                    Hi guys,
                                    If someone would be able to provide some expertise, I'd be very grateful.
                                    BIOS Corruption - Cause
                                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                    09-06-2025, 10:32 AM
                                  • lap-top123
                                    Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                    by lap-top123
                                    HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                    Hp Elitebook 850 G8
                                    ProdID 52W98EC#ABD
                                    SN# 5CG1458XQ7
                                    Mac-address #1: 84:14:4D:2C:4B:5B
                                    UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                    Mainboard : 6050A3216701-MB-A01(A1)
                                    08-20-2025, 07:28 AM
                                  • cepha03
                                    Alienware 17 R2 BIOS Recovery Help + BIOS Flash File Request
                                    by cepha03
                                    Bought a cheap Alienware 17 R2 that doesn't POST. Once turned on, lights illuminate and goes through a continous boot loop of turning off and repeat. I've tried all the easy remedies (Replace RAM/Ctrl+Esc/Clear CMOS/ Replace CMOS/Formatting USB to FAT importing the .rcv file and holding End upon boot). Seems like the only solution now is to reflash the BIOS chip with a programmer. Problem is, there's two. I've provided pictures of both. I'm unable to discern which one I'm supposed to flash so any help would be greatly appreciated. Also, if anyone has it could I also have the BIOS flash file as...
                                    12-14-2025, 08:08 AM
