HP Zbook Power G7 DAXW5AMBAD0 REV D - Endpoint Security Bios issue
  • Gurmon
    • Sep 2012
    • 11
    Can you please assist in removing the"There is a problem with the HP Endpoint Security Controller on the unit" message upon boot
    productid = 43B62EC#UUG
    Serial = 5CD138HQGN
    Mac address B0-22-7A-DE-DD-65
    thankyou in advance​
  • JohnnyJ
    • Oct 2020
    • Sweden
    https://h30434.www3.hp.com/t5/Business-Notebooks/Problem-with-Endpoint-Security-Controller-reported-on-Boot/td-p/7574908
    https://www.google.com/search?q=There+is+a+problem+with+the+HP+Endpoint+Security+Controller+on+the+unit&oq=There+is+a+problem+with+the+HP+Endpoint+Security+Controller+on+the+unit
    • hoaca388
      • Jan 2022
      • 11134
      • Viet Nam
      Serial = 5CD138HQGN
      HP ZBook Power G7 Mobile Workstation
      Become a Badcaps supporter
      Thanks to all supporters.
      • Gurmon
        • Sep 2012
        • 11
        Hi, Thanks for getting back to me,
        However bios in post #3 does not display an image, im just getting fast fans, and then a restart.
        • Kuroneox
          • Feb 2017
          • 24
          • México
          Hello, I need your help. I have a laptop whose bios chip is damaged and I don't have a backup copy.
          Does anyone have a copy?
          HP ZBook Power G7
          DA0XW5MBAD0D
          ProdID 342N2LA#ABM
          Sn#5CD13544P3​
          • ameerrrr
            • Aug 2015
            • 41
            • syria
            sn:2TK12700Q7
            I want to delete the password from the file and make Clear me
            • hoaca388
              • Jan 2022
              • 11134
              • Viet Nam
              sn:2TK12700Q7
              Serial_2TK12700Q7
              Sku_341R4UC#ABA
              Build Id_20WWIODT601#SABA#DABA
              Fearture byte_3X476J6S6b7B7M7Q7U7W7m7s8uaBapaqauawbhcAdUdpdqfPguhKhkjhk8mEnV.my
              Can't clear ME this file.
              • ameerrrr
                • Aug 2015
                • 41
                • syria
                Serial_2TK12700Q7
                Sku_341R4UC#ABA
                I can't get it back on the device if I don't do clean me
                • javier fajardo
                  • Sep 2021
                  • 58
                  • Colombia
                  Hello, could you help me remove the password from HP zbook power g7, thank you very much
                  SN : 5CD05192XW
                  board : daxw5embcf0 rev:f
                  • shiyab
                    • Sep 2023
                    • 1220
                    • india
                    SN : 5CD05192XW
                    HI flash ec file try and feedback
                    • javier fajardo
                      • Sep 2021
                      • 58
                      • Colombia
                      thank you very much, it worked perfectly
                      • marc_ytos
                        • Apr 2020
                        • 137
                        • cdmx
                        Greetings, can you help me with Endpoint Security Controller, my device is zbook power g7, serial number 5CD138DK5F motherboard da0xw5mbad0, thank you very much for your help.
                        • hoaca388
                          • Jan 2022
                          • 11134
                          • Viet Nam
                          • Bios Cracker
                            • Oct 2024
                            • 306
                            • India
                            ENDPOINT SECURITY ERROR FIXED WORKING BIOS.
                            Revert back if it worked.
                            • lazaro.089
                              ZBOOK 14U G6 Corrupted HP endpoint security and HP Sure Start (BIOS REQUEST)
                              by lazaro.089
                              Hi, I have this laptop with a problem, when turning on every time it shows an error message for the HP endpoint security.
                              I tried and flashed a BIOS I found (U367-32Mb) and it worked for a couple of days before it showed up the same error again.
                              Can you help me get rid of this error. Here are both my dumps (U366 and U367)
                              I have some basic skills with Hex editors, if it isn't much trouble, can anyone explain what should I modify so if this problem shows up in another laptop I can fix it in the future?...
                              08-14-2024, 02:05 PM
                            • wizard13
                              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                              by wizard13
                              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                              I have checked the forum and the available documentation but could not find a solution specific to my issue.
                              • Brand & Model: Dynabook Satellite Pro C50D-B-100
                              • Part Number (P/N): PYU13E-00C00PFR
                              • Serial Number (S/N): 22028896H
                              • System Configuration (SC): A1PYU13E1127
                              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                              • Power Input: DC 19V –
                              02-28-2025, 02:43 AM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                              HP Clean VSS2 dumps,fix Endpoint Security error
                              by SMDFlea
                              Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                              the infamous **"Endpoint Security" error message.
                              Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                              I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                              The offsets and file sizes are part of the naming convention i`ve used for the extracted
                              files.
                              hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                              filling everything after...
                              08-08-2024, 03:14 PM
                            • SGVsbG8sIHdvcmxkIQ
                              Issue wtih [crisis] BIOS recovery
                              by SGVsbG8sIHdvcmxkIQ
                              BIOS update bricked my laptop - after restart the was a prompt to Proceed with ROM flash or Abort. None of 2 options worked - upon restart the same prompt shown.
                              I downloaded [BIOS update].exe file from Lenovo Support > extracted [firmware descriptor].fd file > renamed it to [correct crisis file name].bin.
                              With crisis file on USB drive the Proceed with ROM option launches recovery - after displaying the current and the new BIOS version, the process terminated immediately with validation error:
                              Not allow flash. Boot Guard version verification...
                              04-28-2024, 03:43 PM
