Dead Lenovo Thinkpad Edge E520 (BIOS ?)
  • sandrabrnelic
    • Mar 2012
    • 34
    • Croatia
    I have one dead E520. It's completly dead. Nothing happens when i push power button. Reading over internet i had found that whole batch of E520 produced in second half of 2011. had issues with eeprom (this one is from 2011.) and that they behave like mine E520 (no power, completly dead). So i took the eeprom out (MX25L3206) and read its content to check if it's alive. And i was able to read it ... Now the problem is that i don't know if eeprom content is OK. So i want to program it with fresh BIOS from lenowo website. But on Lenovo website i was able to find only eeprom in .FL1 format and it's 2.621.440 bytes large (MX25L3206 is 4.194.304 bytes). So i need correct BIOS file for my programmer.
    Sorry for my bad english.
    Please help.
  • khaahk
    • Dec 2013
    • 767
    • Estonia
    Re: Dead Lenovo Thinkpad Edge E520 (BIOS ?)
    Try this and please report back. Not 100% sure it is working.
    • lord
      • May 2011
      • 319
      • Croatia
      Do you have voltage on the power button?
      • sandrabrnelic
        • Mar 2012
        • 34
        • Croatia
        Update:
        @khaak, thank you
        @lord, yes power button has 3V and this is OK
        I have investigated a little bit more ...
        Standby power ic BD9528 is not working, so maybe BIOS is OK.
        BD9528 has 20V on Vin(30), 3,2V on EN1(21),EN2(4) but output is low. Linear regulator output is ok REG1 5V, REG2 3.3V. But switching regulator outputs are low. Instead of 3,3V it has 0,7V and instead of 5V there is 0,4V. There is one more strange thing on REF(12) pin i have measured 0.7V and in schematic i have this pin is named REF2V so i think it must be 2V, even resistor divider for feedback is set to give 2V on feedback pin when output is OK (3,3V). I'm not shure what to do next ... do i need to change BD9528 or i can check something else before that.
        This is shematic i have: it's e420 but i think it is same or very similar, board is LGG-1 MB.
        This one is also confusing me because he speaks of two versions of DB9528 with 0,7 and 2V Vref: http://forums.lenovo.com/t5/ThinkPad...1225069#M21664
        • lord
          • May 2011
          • 319
          • Croatia
          Can't find DB9528 in schematics.
          Check pin 14 on U2701 when you press the power button.
          • sandrabrnelic
            • Mar 2012
            • 34
            • Croatia
            My fault, it's BD9528 ..
            • lord
              • May 2011
              • 319
              • Croatia
              As described in voltage rail activity table on page 3 only 3D3_PWR_2 should be active when laptop is off. Check what i told you in post#5 if your U2701 is NPCE795GA0DX and get back with results.
              • sandrabrnelic
                • Mar 2012
                • 34
                • Croatia
                I can't see 3D3_PWR_2 in voltage rail table. Do we have same schematic ?
                Pin 14 on my U2701 is 3.2V regardless of power button state and yes it's NPCE795GA0DX.
                • lord
                  • May 2011
                  • 319
                  • Croatia
                  3D3_PWR_2 transfers from 3DV3_AUX_S5 through PR4122 (page 41).
                  Pin 14 which is the S5_ENABLE should be low until you press the power button.
                  • lord
                    • May 2011
                    • 319
                    • Croatia
                    So either or the EEPROM or the U2701, but my vote is on U2701.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Any update on this?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Found this on another forum:
                        Finally E420s motherboard REVIVED / FIXED / REPAIRED !!!
                        After serious efforts and wasting substantial amount of cash and time (and lotsss of reading :smileyhappy:.... ) I have managed to revive my Lenovo E420s motherboard . Even I have contacted WISTRON company the one designing and manufacturing the MB for LENOVO. I asked them for the electrical schematic for this MB but as you can guess NO SUCCESS.
                        On my previous posts I have asked if there are folks who want to sell their faulty motherboards and the reason was simple, wanted to test and see if they have the same issue but.......... no one was interested in selling faulty E420s MB.
                        Here are the specs of my Lenovo E420s:
                        CPU: Intel iCore 5 2nd generation
                        RAM: 16GB, 2 x 8GB
                        Video: Intel 3000HD
                        SSD: 64GB msata, MyDigitalDiscount BulletProof
                        HDD: 500GB, Hitachi 7mm, 5400rpm
                        2nd HDD: SATA caddy with 1TB 9.5mm (DVD was replaced with an HDD caddy)
                        Anyway, let us get to the problem first and then to the solution:
                        - PROBLEM (the one that I had)
                        Whilst the laptop was perfectly working it suddenly powered/went off for no reason (the same as you pull the power cord from a DESKTOP PC). When I tried to power up, the first couple of times of pushing the power button did not work but I was persistent and after of couple of more pushes the laptop powered up, lucky me :smileyhappy:. The interesting thing here was LENOVO power management gauge (green battery gauge on the bottom right corner next to system tray) was indicating that laptop is connected to the power adapter but the battery was draining/discharging. I was just watching how the battery is depleting till it was fully empty and the laptop went off and never powered up again.
                        There was no indication at all for anything - NO RED LIGHT on the dot of "i" and the green LED next to the power jack was off even though the power adapter was connected to the laptop. BTW this green LED indicates if your laptop is charging the battery.
                        here i am gonna skip the all the non senses that i have done in order to get my laptop working again and go straight for the solution. All the images (only 3 images :smileywink: ) are uploaded on my dropbox and you can download them from there.
                        Here is the link: https://www.dropbox.com/sh/3o1njwwgvfjho2n/ma8fpW7wKt
                        - Solution:
                        1. You have to disassemble the laptop and to take out the system board or for shortly MB.
                        Please remove all the components from the MB. You have to end up only with bare MB with components which are soldered on it. you can keep the cpu and gpu and the cooling assembly on. Refer to the image named top_MB_e420s.jpg
                        2. On the bottom side of the MB there is one connector with 5 pins which provides the POWER for the MB. The cable connected to this connector is coming from the POWER JACK of the laptop in our case this is the 20V voltage power source from the power adapter. Have a look at image bottom_MB_e420s.jpg the yellow square.
                        3. NEXT to this connector there are 2 small chips with 8 pins. These 2 chips are MOSFET transistors (both of them are same part number) and they are acting as a SWITCH or with other words as a POWER SOURCE SELECTOR. To visualize how these 2 MOSFETs are connected have a look at Fig.1 on this webpage: "http://www.eetimes.com/design/power-management-design/4012528/Fundamentals-of-designing-with-MOSFET-...". No harm will be done if you want to read the whole article as well. Please check image named "bottom_MB_e420s.jpg" red rectangular.
                        4. After measuring these 2 MOSFETs with multimeter I have established that one of them was gone / faulty. Here is the MOSFETs part number: FDS6675BZ - this is P-channel 30V 11A. You can get 6pcs from ebay for only USD 3-4.
                        Here I would recommend to replace both MOSFETs. DO NOT replace only the faulty one. For more information you can refer to the datasheet of the MOSFET. Refer to image named "bottom_MB_e420s.jpg" for locating the MOSFETs.
                        PLEASE BE AWARE MOSFETS ARE VERY SENSITIVE TO STATIC ELECTRICITY. IF YOU GOING TO DO DESOLDERING AND SOLDERING BY YOURSELF PLEASE WEAR ANTISTATIC WRIST STRIP or TAKE NECESSARY ANTISTATIC PRECAUTIONS.
                        So for my case scenario these MOSFETs were the problem by replacing them everything worked just fine with no problem at all. I left the laptop running for 48 hours no problem observed, I have restarted it couple of times with no issues as well and reinstalled the OS.
                        I have another faulty E420s MB and the MOSFETs there are with the following part numbers: AO4407A. As you can guess the problem with this MB is the same - one of the MOSFETs is gone. This MOSFET is identical to the above mentioned and you can interchange this one with the above mentioned MOSFET. Please refer to the datasheet to check the most important parameters Id, Vd, Rds.
                        This MB have not fixed yet due to blowing a small SMD resistor 0.01ohm ohm and now I cannot find this SMD resistor. I f you can help me find this resistor from somewhere will appreciate very much.
                        On my dropbox public folder I have uploaded the location of the BIOS chip as well. It is only for your information.
                        So, I hope this will help most of you to revive your Lenovo E420s laptop and start using it again.
                        If this info helped you to revive your e420s I will appreciate your donation to recover some of the cash that i have wasted to repair this MB.
                        you can donate to my paypal here is the email:xxxxxxxxxxxxxxxx
                        If you have any questions feel free to contact me on the same email will try my best to help you all.
                        Thank you!
                        And Good Luck!
                        p.s.
                        I have just added and the hardware service manual from lenovo for e420s. this will help you to disassemble and assemble your laptop. :smileywink:
                        • tibimakai
                          • Jan 2012
                          • 3680
                          https://forums.lenovo.com/t5/11e-Win.../667009/page/8
                          • trebo
                            • 514
                            • Wales, UK
                            can't get your dropbox images
                            • tibimakai
                              • Jan 2012
                              • 3680
                              It's not mine. It seems like the link is dead.
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                sandra replace the regulator and all will be good
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  How can I know, if it's a power issue or EEPROM issue?
                                  Which part is, that has to be replaced? There are not the MOSFETS, like in that other forum?
                                  I'm picking up later on, a E520 i3 laptop and I don't have a service manual yet.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    OK, I have picked it up and took it apart, but I don't know what to do from here on.
                                    Any pointers what should I measure first?
                                    At AO4407A, I measure D= 20.36V, G= 6.68V and S= 20.36V
                                    Any help would be appreciated.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I have started measuring the BD9528 IC and the Vreg1 and Vreg2, show 3.3V and 5V(pin #28, 29).
                                      What else should I measure, to be sure if it's good or bad?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Nobody can help at all?
                                        I'm a beginner, but I have tools and instruments to measure anything that I need to measure.
                                        I'm repairing LCD TVs, home theater receivers, etc.
                                        Any pointers, on what should I look for?
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
