NP930XED Samsung Galaxy Book2 Pro Laptop Firmware Fix request
  • sikocan
    • Oct 2019
    • 338
    As per original post here:
    https://www.badcaps.net/forum/troubl...-firmware-loop
    Attached are 2 chip dumps. I've removed windows serial from BIOS file. Please let me know if there is anything I can try?
    Device serial/model details:
    R11HFT4300147 11297 BA92-23239B 04 02 DAP-3A DAP201501 VENUS2-13 ADL NPC M0U901T4600100
  • sikocan
    • Oct 2019
    • 338
    Following the guide on https://www.badcaps.net/forum/troubl...update?t=88206 here is the extracted BIOS.
    • Gcs_rma
      Banned
      • Dec 2023
      • 108
      • N/A
      NP930XEDA-EXP, NT930XEDA-CSM, NT930XEDA-GOV ITEM_20220307_22090_DOS_P05RGE.zip
      • sikocan
        • Oct 2019
        • 338
        Thanks for sharing. What are these 2 files for in your zip file?
        amiflashefi.nsh
        AfuEfix64.efi (maybe for 25q80dvnjg chip? Not sure).
        Thanks again for sharing.
        Ahh, after seeing this, https://pdfcoffee.com/how-to-update-...-pdf-free.html, the AfuEfix64.efi is a command line software run in uefi shell. How do you get into uefi shell.
        • Gcs_rma
          Banned
          • Dec 2023
          • 108
          • N/A
          amiflashefi.nsh
          you flash bios 32mb 25r256v
          • sikocan
            • Oct 2019
            • 338
            This is the result, https://www.youtube.com/watch?v=bjXgEoP91As
            It does not pass POST. It's boot looping. The Charger LED actually has a diagnostic LEDs which is pretty cool, too bad it's documentation not available. But in this case, obviously BIOS is not compatible most likely.
            • Gcs_rma
              Banned
              • Dec 2023
              • 108
              • N/A
              Need picture mainboard
              • Gcs_rma
                Banned
                • Dec 2023
                • 108
                • N/A
                try Click image for larger version
                [ATTACH]n3177345[/ATTACH]
                  • 20300
                  DMI
                  10A0094 - 10A015F
                  10A2000 - 10A203F (key XXXXX-XXXXX-XXXXX-XXXXX-XXXXX)​
                    • 20300
                    Try the P12RGE bios above.If it doesn`t work flash 1MB of zeros or FF`s to the PD FW chip from this post https://www.badcaps.net/forum/troubl...ware#post74354 .Try booting on battery only if there`s plenty of charge in it.If it boots to windows run the bios update exe ,and see if it will flash the firmware or not
                    • sikocan
                      • Oct 2019
                      • 338
                      I'll try tomorrow. Thank you
                      • sikocan
                        • Oct 2019
                        • 338
                        Pictures attached.
                        try Click image for larger version  Name:	2024-01-12_222828.png Views:	25 Size:	9.4 KB ID:	3177344
                        I've tried this, the behaviour is same as original fault. After programming, with a full battery only, no charger connected, turned on, Samsung logo flashed 3 times over 2 minutes or so eventually turned on as usual, the same behaviour persists, starts into PD firmware update on a loop.
                        • sikocan
                          • Oct 2019
                          • 338
                          Hi mate,
                          Which is the PD Firmware chip?, is it the 25Q80DVNIG?
                          DMI
                          10A0094 - 10A015F
                          I marked the Windows serial number as XXXXX to protect the owner's device.
                            • 20300
                            Hi mate,
                            Which is the PD Firmware chip?, is it the 25Q80DVNIG? , Yes the 1MB chip
                            I marked the Windows serial number as XXXXX to protect the owner's device . Yes i know, ive given the offsets so that other members can use their own from their backups.
                            I`ll post some firmware for you to try later,i don`t know if it will work or not.
                            • sikocan
                              • Oct 2019
                              • 338
                              Alright, thanks, so I'm going to now write 0s into the 1mb chip and update you tomorrow.
                                • 20300
                                Try these as well.
                                • sikocan
                                  • Oct 2019
                                  • 338
                                  Hi mate, it's the same result with these 2 test1/2 zip files. As mentioned before the same PD firmware update happens without this chip installed meaning most likely it's actually programing the PD chip that I've replaced. Looking at the sellers description and title shows that this is a programmable chip.
                                  https://s.click.aliexpress.com/e/_DeNsf89 - "CYPD6227-96BZXI FLASH(64kB)ROM(96KB)"
                                  I believe this is the issue.
                                  • sikocan
                                    • Oct 2019
                                    • 338
                                    I've realised my mistake, my original chip was CYPD6228 not CYPD6227. Damn. I'll get new chip and try again. Sorry to have wasted all of your time team. Thank you.
                                      SMDFlea commented
                                      Editing a comment
                                      Mistakes happen. Flash the original 1MB backup back again as its signed with an RSA public key.
                                  • E4TLESS
                                    • Dec 2023
                                    • 21
                                    • Ghana
                                    Any update on this? Did you get the correct chip and tested it out. Is the PC working now with all bios issues fixed?
                                    • sikocan
                                      • Oct 2019
                                      • 338
                                      Correct chip fixed the issue.
                                        Samsung Galaxy Book2 Pro NP930XED-KA2FR Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book2 Pro NP930XED-KA2FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XED-KA2FR boardview and NP930XED-KA2FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:20 AM
                                        Samsung Galaxy Book2 Pro K/NP930XED-KA3FR+MU-PC1T0T/WW Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book2 Pro K/NP930XED-KA3FR+MU-PC1T0T/WW Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the K/NP930XED-KA3FR+MU-PC1T0T/WW boardview and K/NP930XED-KA3FR+MU-PC1T0T/WW schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GALAXY BOOK2 PRO 360 15.6 boardview and GALAXY BOOK2 PRO 360 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-07-2024, 06:11 AM
                                        Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Pro boardview and Galaxy Book2 Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
