Clevo W253EU bios file needed
  • con23
    • Dec 2023
    • Ελλάδα
    I have a Clevo W253EU laptop that the screen does not open and the fan starts at maximum speed I think it is a problem in the bios and for that I need the bin file to reprogram it. I know the website https://repo.palkeo.com/clevo-mirror/W2xxEU/ and I have downloaded the appropriate bios update but it is not in bin format And it is in 6mb (W240EU.03) which does not fit in this case what can i do ? I have the ch341a programmer
    • 21685
    It needs splitting to 2MB and 4MB. You can do that with a hex editor or use FIT Flash Image Tool. Open the 6MB bios with ME Analyzer and check the firmware version (its 8.1) .Download ME System Tools v8 from https://mega.nz/folder/qdVAyDSB#FLCPaDVIsPYiy2TAUjD7RQ .Extract the system tools,inside the Flash Image Tool folder there are 2 versions, just choose the oldest.Run fitc.exe ,drag the 6MB bios onto the fitc window.Click on build/build image .Inside the Build folder fitc has split the 6MB bios into a 2MB outimage(1).bin and 4MB outimage(2).bin .There are 2 bios chips on your board,flash both of them,but make backups first.
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • wakethesleep1111
      Bios File Needed for asus tuf15
      by wakethesleep1111
      Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
      05-27-2025, 10:56 PM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • kamkam336
      Alienware Aurora R8/9 Bios .bin file needed
      by kamkam336
      I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
      Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
      Thanks ...
      08-19-2024, 06:59 PM
