HP Probook x360 435 G7 Endpoint Security Controller
  • mego1974
    • Feb 2022
    • 43
    • Spain
    Hello
    i need help
    I have a laptop HP Probook x360 435 G7 with bios password
    I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
    I have read the both bios chips and i have posted a picture with the chips pozition.
    Can anybody help me with intruction or look on the dump if something is wrong ?
    Thanks in advance!!
    Edit
    Serial 5CG03947C4
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    TRY
    • mego1974
      • Feb 2022
      • 43
      • Spain
      Thanks !!!!
      It works !!!
      Thank you very much !!!!
      • omenwolf
        • Jul 2018
        • 66
        • Odessa
        Hello!))) please remove bios password my serial number: 5CG0340QQ0
          • 22283
          Have you tried using RCUnlocker https://www.badcaps.net/forum/troubl...=4#post1622423
          • rex98
            • Feb 2023
            • 1297
            • Mandaue CEBU, Philippines
            if you want complicated unlocking use this.
            here use this only flash u367
            first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
            use BCU. you can permanently disable Absolute lock in BCU.
            here's your DMI:
            Serial Number: 5CG0340QQ0
            Product #/SKU: 213V7ES#ABU
            CT Number: PJSBC00WBE30AK
            Description: HP ProBook x360 435 G7
            BuildID: 20WWPMAT601#SABU#DABU
            Feature Byte: 3X476J6b7B7J7M7R7W7m7s9AaBaQapaqauawbVcAdUdpdqeMfPk8mEmVn5.r7
            MAC Address : 9C:EB:E8:7C:C0:41
            • omenwolf
              • Jul 2018
              • 66
              • Odessa
              here's your DMI:
              with this, no start, no response to the button
              • omenwolf
                • Jul 2018
                • 66
                • Odessa
                Thank you!!!! helped
                • oceks
                  • Feb 2017
                  • 11
                  • tukey
                  Originally posted by mego1974
                  Hello
                  i need help
                  Thanks in advance!!
                  Edit
                  Serial 5CG03947C4
                  Thanks..it works
                  • fede77
                    Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                    by fede77
                    Notebook HP ProBook 450 G8
                    ProdID 2K8L1LT#AC8
                    Mother: DAX8QAMB8D0 REV D
                    The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                    03-10-2025, 07:12 AM
                  • jmp9155
                    i have hp probook 640 g4 stucks hp endpoint security controller
                    by jmp9155
                    accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
                    any solution for this issue?
                    07-09-2024, 06:23 AM
                  • kolebbk
                    HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                    by kolebbk
                    Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                    HP Endpoint Security Controller problem
                    there is a problem with the hp endpoint security controller on the unit
                    I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                    09-04-2024, 12:44 AM
                  • spider300
                    HP ProBook 430 G8 hp endpoint security controller problem
                    by spider300
                    please Help Me ... ProBook 430 G8
                    HP EndPoint Security Controller Problem...
                    07-11-2023, 08:40 AM
                  • DonZott
                    HP ProBook 650 G8 - Endpoint Security Controller Problem
                    by DonZott
                    I have a HP Probook 650 G8 with the error "There is a problem with the HP Endpoint Security Controller on the unit."
                    After searching on the forum I've opened the device to check what IC's were on the motherboard and I found some corrosion on the pins of the EC ROM.
                    So my guess is that the EC got corrupted?
                    After some more searching on the forum I've found some other threads where this issue was brought up after they removed the password, this is not the case here, the laptop did not have any password and I did not modify the...
                    03-30-2023, 04:26 AM
