Thinkpad T14 Gen 1 Ryzen 7 NM-C801
  • trepachka
    • Oct 2022
    • 424
    Hello, I have a Thinkpad T14 Gen 1 Ryzen 7 processor
    Computer turns on but no keyboard backlight / no video. I get all the voltages, cpu gets hot, fan spins. I think it's bad BIOS issue.
    Please, help me rebuild the bios:
    NM-C801 motherboard
    Serial# PF2RRNX4
    Type: 20UD-000GUS
    • 20863
    NM-C801 motherboard
    Serial# PF2RRNX4
    Type: 20UD-000GUS
    Could you possibly make a backup of the eeprom marked UPTU2 in schematic to help one of our other members ?
    https://www.badcaps.net/forum/troubl...2-in-schematic
    • trepachka
      • Oct 2022
      • 424
      How do I do that? I only have CH341a.
      • trepachka
        • Oct 2022
        • 424
        SMDFlea, perhaps I can fix the bios first to confirm computer boots. Then, may be you can walk me thru how to extract eeprom (UPTU2) using basic tools. Can I still use CH341a for this job?
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          What is the model labeld in the UPTU2?
          • servis_null
            • Oct 2014
            • 82
            • Croatia
            I got T14 Gen1 with no image on LCD and HDMI after BIOS flash failed. Machine powered off during update procedure. Laptop reacts normal on power button, also CPU is heating and fan reacts normal. I tried multiple bios dumps, but looks like problem is somewhere else. Got another board that also failed on bios update and it acts same.
            Machine details are:
            Type: 20UE-S0VT01
            SN: PF-35YE3K
            Board model: NM-C801
            I need dumps of following eeproms so I can try this as last step..
            Motherbard marking / IC model / Package - IMAGE OF LOCATION PROVIDED
            UC3 / W25Q128JWSIQ / SOIC8 - 200mil - FILE ATTACHED
            U15 / W25Q80JVSSIQ / SOIC8 - 200mil
            UPTU2 / W25Q40CLSNIG / WSON8 6x5 (for some reason schematic shows W25Q80DVZPIG) - FILE ATTACHED
            UL5 / W25Q80DVSNIG / SOIC8 - 150mil
            U2 / IT5261-512-AX / VFBGA
            U3 / IT8300FN-CX-R / QFN48 6x6​
            Thnx to everyone
            • meta99
              • Sep 2021
              • 27
              • Vietnam
              Please help
              There is no sign of life when connecting charger to both of two USB-C ports on my Thinkpad T14 Gen 1 AMD but it still with battery connected. I think there is a U15 ROM chip in the back side of mother board incharge of PD Controller. I need dump of this U15 Eeproms to try.
              Type: 20UD-000HUS
              SN: PF-2E5SSE
              U15: WINBOND W25Q80
              Thanks a lot​
              • kamel
                • May 2011
                • 118
                • TUNISIA
                Hello members
                Need urgently Embedded Controller clean dump for Lenovo thinkpad T14 gen 1 Amd Ryzen Pro
                MB : GT 4A1-NM-C801 to help remove supervisor password.
                Many thanks
                  • 20863
                  Originally posted by kamel
                  Hello members
                  Many thanks
                  Thread merged. Post the laptop serial number..... as per the rules . Can you help other members by posting the other dumps https://www.badcaps.net/forum/troubl...55#post3203655
                  • kamel
                    • May 2011
                    • 118
                    • TUNISIA
                    Thinkpad-t14-gen-1 serial number : PF-31GJNV and type number : 20UE
                    Once I solve the locked bios issue, I will make a back up of every bios chip and post them for members.
                      • 20863
                      Can you post your EC backup
                      • servis_null
                        • Oct 2014
                        • 82
                        • Croatia
                        can you please make backup / dump of every eeprom on board? List of eeproms and locations is in this post - https://www.badcaps.net/forum/troubl...55#post3203655
                        Thank you very much
                        • kamel
                          • May 2011
                          • 118
                          • TUNISIA
                          Couldn't backup EC, have to solve this issue :
                          I have micro_Vision programmer Rev: 4.1 with connectors supporting Max 32 pins, whereas T14 keyboard connector has 40 pins. I tried to read the IT5261VG-512 EC with a 32 pin cable 0.5mm but always got error reading message "ITE do not respond check connection and settings MB powered ? (02)", though all pins to read are within the 24 1st pins (so connected to programmer) ?
                          Any suggestion should be well apreciated.
                            • 20863
                            This programmer https://www.aliexpress.com/i/1005004829637690.html ,it looks like a vertyanov clone
                            • servis_null
                              • Oct 2014
                              • 82
                              • Croatia
                              • kamel
                                • May 2011
                                • 118
                                • TUNISIA
                                First, thanks for the photos.
                                Yes indeed, also vertyanov programming software is compatible with MIC-VISION JIG V3.
                                I did connect the programmer and MB the same way as in the photos and got error "Ite do not respond". But i have to correct, I rather 1st used the 30 pin 0.5mm cable supplied with programmer. Today I solved the issue once I used the 32 pin 0.5mm cable instead (which was supplied with my old svod1 ver2 programmer). So I saved the EC .bin file with password which I attach.
                                Is their a way to remove the password from the .bin file ? please share. Thanks
                                • kamel
                                  • May 2011
                                  • 118
                                  • TUNISIA
                                  Attached EC backup of theT14 Gen 1 password protected.
                                  • Laptop@Expert
                                    • Jan 2023
                                    • 6
                                    • pakistan
                                    Please ITE unlock NM-C801
                                    • peste
                                      • Dec 2016
                                      • 12787
                                      • ROMANIA
                                      post S/N, full name and model, nodel ITE,TYPE,etc..
                                      • shuhaibvc
                                        • Aug 2018
                                        • 13
                                        • united arab emirates
                                        HI, EVERYONE, HELP ME UNLOCK EC ITE
                                        MODEL LENOVO T14
                                        TYPE: 20UE-S0X247
                                        SERIAL NUMBER :PF-2PLW6S
                                        NM-C801
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
