Help with Thinkpad Maintenace Utility on T590
  • x16
    • May 2015
    • 83
    i unlocked my T590 with SVOD4 and wrote new ec from lenovo site. Now password is gone but dmi is missing now. So i have to write it back with Thinkpad Maintenace Utility.
    I now have newest version of lenovo U1 golden key software (3.5.52) for USB boot stick. This tool starts the Thinkpad Maintenace Utility V1.20.
    But i can't initialize eeprom. It says: "ERROR: Written data is unmatch."
    So i can't write sn number without initializing it first.
    Any ideas?
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1226
    • France
    can you post your EC dumps?
    have you tried planar services?
    with dump eeprom (5), are there serials and information marked in it ?
    you can try with SERUPDT (exemple 7 and 8 in my pics)
    Click image for larger version Name:	399779571_217912041320157_5257554185771111853_n.jpg Views:	0 Size:	407.8 KB ID:	3156564
    with lenovo diskette
    create eeprom.dat with serial info
    place in root of usbkey
    IN EFI SHELL
    cd A:\MTMSN\ThinkPad\
    for write
    SERUPDT L eeprom.dat
    for save in eeprom.dat
    SERUPDT S eeprom.dat
    Click image for larger version Name:	386453902_1041202147221888_1671781784116666234_n.jpg Views:	0 Size:	20.4 KB ID:	3156563
    • x16
      • May 2015
      • 83
      Here the 2 files of EC dump.
      I tried planer service. It is empty. If i want to add, i write this:
      1S20N5S56P00PF272VRD
      It says the SN is ok but one line under it says: "Invalid configuration information area"
      Even dump eeprom dump(5) is empty, all with 00 filled
      • Maxpower3
        Maxpower3 commented
        Editing a comment
        have you tried cleaning the setup?
        In security and tpm chip everything cleaned and then 2 empty password and then a load and save by default
        retest after
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1226
      • France
      Do you have the page titles block 0/1 SER# Block 2/3 USR# Block 4/5 CON# displayed with dump eeprom?
      in A:\MTMSN\ThinkPad\bootx64
      with HxD
      find two times 43 00 45 00 45 00 50 00 5F 00 49 00 4E 00 49 00 54 00 20 00 2D replace Y by C
      and go init eeprom
      -S (Initialize serialize information)
      -U (Initialize user information)
      -C (Initialize configuration information)
      -Y Full init
      Click image for larger version Name:	386453902_1041202147221888_1671781784116666234_n.jpg Views:	0 Size:	196.5 KB ID:	3156583
      • x16
        • May 2015
        • 83
        With dump eeprom i can see Block 0,1 / Block 2,3 / Block 4,5 / Block 6,7
        And yes i load standard options with F9 then cleaned all security options.
        What I have noticed is that I cannot set a password. When I set a password in the bios and restart, no password is set.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1226
          • France
          even initialize it must not be EMPTY
          you can even see the magic number AA55 at the end of the 5 pages
          Click image for larger version Name:	365436541_269263119198220_3988259081739509859_n.jpg Views:	0 Size:	1.36 MB ID:	3156599
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            we find the different pages in bootx64 written on EC
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1226
              • France
              you can see status of password under windows with script. put both files on the desktop
              • x16
                • May 2015
                • 83
                Thank you very much for your help.
                Here the results:
                IN EFI SHELL
                This dont work because i have no diskette. If i try this with boot stick, then shell doesn't know the command serupdt
                retest after
                Yes i do but no luck after trying to initialize eeprom
                Yes but there are no words like SER# USR# or CON#
                with HxD
                and go init eeprom
                I did it but no change. I even dit it in ThinkPadT directory to be sure. Filename in both directorys is BootX64t.efi
                yes i can see this number, but initialize is not successfull, so nothing is written in eeprom: "ERROR: Written data is unmatch."
                I don't understand what you mean
                Statuscode is 0
                I don't know if it is important, but i have no harddrive, Display, Keyboard connected to the T590. I'm working with usb Keyboard, HDMI Display.
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1226
                  • France
                  This is not normal, someone with a T590 or equivalent on hand to display the pages.
                  Can you post pics of yours?
                  For me it must have the titles at the beginning of each block
                  look my video here
                  https://www.badcaps.net/forum/troubl...63#post1831963
                  you can see the beginnings of the block. I'm not sure about myself for T590 or after but it must be the same.
                  can someone confirm​ please
                  • x16
                    • May 2015
                    • 83
                    Yes on your Video i can see SER#........ but not in mine.
                    Here is my Video:
                    (First i press 1 for initialize, then 2 for dump)
                    • Maxpower3
                      Maxpower3 commented
                      Editing a comment
                      you have done the maintenance key with usbfmtpw.exe to have access rights.
                      Otherwise it could also pose a problem.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1226
                    • France
                    Here is my Video:
                    the dump is completely blank, that's not okay!!
                    you see that it wants to write SER# in block 0/1 but it doesn't happen because the information doesn't match.
                    Why doesn't he try the other blocks too, he stops.
                    did you put EEPINIT -Y back correctly?​
                    post your golden key, I don't have this version please
                    • x16
                      • May 2015
                      • 83
                      Yes, i installed Windows 7 on an old Laptop to get usbfmtpw.exe to work. There i formated it with usbfmtpw.exe and then did the rest with U1. I even tryed with second USB Stick with 4GB. But same result.
                      Maybe i damaged de mec chip? It was the first time i unlock with svod4. First i tried read and write back but passoword not gone, then i do this:
                      What i did with svod4 tool:
                      - read mec main with 192kb
                      - read mec main with 256kb
                      - read mec main with 288kb
                      - read mec eeprom with 2kb
                      - erased mec main with 192kb
                      - erased mec main with 256kb
                      - erased mec main with 288kb
                      - erased mec eeprom with 2kb
                      - write mec with new main ec from lenovo homepage 256kb
                      I know it was to much. Maybee i should only delete eeprom with 2kb next time?
                      • x16
                        • May 2015
                        • 83
                        Can't i write it manualy with the dump of EC? Or other way?
                        What do you mean? You mean that with BootX64t.efi? Then yes i deleted the stick and completey made new one with U1.
                        Of course:
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1226
                          • France
                          have you tried with a clean bios like here?
                          https://www.badcaps.net/forum/troubl...64#post1864864
                          • x16
                            • May 2015
                            • 83
                            Yes i tried this but no luck. I think mec ist locked or something like this. Maybee i do something wrong.
                            For nextime: just read eeprom with svod4 and write it back? Is this right? Then dmi data isn't get lost?
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              here the 4 blocks, read on a T590
                              Click image for larger version  Name:	406360780_843288264147488_6871955227433131275_n.jpg Views:	0 Size:	1.27 MB ID:	3157832 Click image for larger version  Name:	400865812_1088683599243027_2888667166992596740_n.jpg Views:	0 Size:	1.32 MB ID:	3157833 Click image for larger version  Name:	400494683_879831300385520_1758401697899313637_n.jpg Views:	0 Size:	1.28 MB ID:	3157834 Click image for larger version  Name:	406670622_284067567554636_3243226384332222195_n.jpg Views:	0 Size:	1.27 MB ID:	3157836
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1226
                                • France
                                The password is once again hidden at 0x300 in EC eeprom
                                I get the impression by comparing.
                                just clean from 300 to 35F maybe necessary?
                                (after analyse 300 to 34F should be sufficient, see photos above of the T590 without password)
                                Click image for larger version  Name:	406360780_843288264147488_6871955227433131275_n.jpg Views:	0 Size:	541.7 KB ID:	3157977
                                here's how it is for me!
                                Maybe I'm all wrong, I don't know,)
                                Click image for larger version  Name:	406360780_843288264147488_6871955227433131275_n.jpg Views:	0 Size:	485.1 KB ID:	3157986
                                the number of header characters is identical and a lot of similarity compared to the photos of the eeprom dump above
                                I'm pretty sure that's it
                                • x16
                                  • May 2015
                                  • 83
                                  OK i try it...
                                • keczuk
                                  • Dec 2019
                                  • 83
                                  • WWW
                                  IN EFI SHELL
                                  for write
                                  Can u share your disk ?? i want try read and save EC info but i don't have option in my Lenovo disk and i use command but not working, show me is not recognise command.
                                  IN EFI SHELL
                                  for write
                                  SERUPDT S eeprom.dat zz0.tv1brsjeiazz
                                    Lenovo ThinkPad T590 Notebook T Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad T590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T590 boardview and T590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                    09-06-2024, 03:30 PM
                                    09-06-2024, 03:21 PM
