Lenovo Thinkpad T495 AMD bios password locked
Hi! I tried patching and writing the bios to my ThinkPad T495 but it seems that the original dump was corrupted. Now the laptop doesn't boot even when I flash the original dump. Anyway to save the machine ? -
Hi y'all. Would anyone happen to have some advice? After I did the Lenovo autopatcher, no post, black screen. I tried with a different bios as well, same result. Original bios working, but it needs password.
The original bios is in the attachments as well the patched
FA495 NM-C131 rev 1
Attached FilesLast edited by Nagyesz; 04-09-2025, 04:22 AM.Leave a comment:
Hello. I bought this laptop T495 and i think he have autopilot or MDM i don't know sure.. but the thing is that i can't install windows on it.. after i install windows i have to log somewhere.. this happened few days ago.. but now.. after i tried few things i generated another UUID and now this laptop can't connect to that server or idk how to call it... "mother ship ". I will attach bellow one picture. And one more thing. I saw that in bios i have OA3 license installed, preinstalled license. And one more thing, the laptop had supervisor password on bios.. but i managed remove it and to disable everything on bios that could block me to install the windows. It's there a way to resolve my problem? Thank you very much!Leave a comment:
Finally I get it working again by flashing the #22 bin file...Now I have a no password bios!!! So the problem was not using 1.8v adapter
Thank you for your support!!
Just last question: why you say to restore original dump if with patched one all is ok?Leave a comment:
You are right but it was my mistake because I try to read and flash with the clamp not fitted correctly but now after 10000 try I fit it and bacause I'm not able to desolder it I want to try to restore the laptop in this way. I disconnect the ch431a but not the clamp and now the laptop play some strange sounds (bip bip...) and nothing else
​​I not want to disconnect the clamp because if I have to flash another firmware I not want to make again 10000 try to fit it.Leave a comment:
The 1.8V adapter just arrive I follow this steps but after patching with the generated patch file (STEP1) the fan start fast but screen stay black and after the laptop shutdown itself.
I'm trying to power one the laptop with the ch341 clamp attached but not inserted to usb because I'm not able to desolder it and I spend some hours to fit the clamp.
Please can you help me?Leave a comment:
1st use patched file to unlock bios following steps described in autopatcher:
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
at step 8 use T495_new.bin Because your backup is corrupted I'm not sure your DMI is ok, if you get message that serial, MTM, etc. is missing use Lenovo Maintenance Utility to restore original serial, MTM.
Thank you I will try it but to make sure I do things right:
I must use the 1.8V adapter and I have to desolder the chip. Is right?
at step 8 use T495_new.bin Because your backup is corrupted I'm not sure your DMI is ok, if you get message that serial, MTM, etc. is missing use Lenovo Maintenance Utility to restore original serial, MTM.Attached FilesLeave a comment:
yes, I will try to build a new bios from bios update, patch it and see how it works.Leave a comment:
this proves once again that you didn't read bios guides! As beginner into bios mod this should be your 1st step, ppl with way more experience than you made that guide. Since you write back bios backup you made with clamps and laptop doesn't start this should tell you that your bios backup is corrupted! And yet you ask "Why i can't use the soic clamp?" !!!
" It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible.
If you insist on using a clip, then make sure the programmer uses an additional buffer and line driver for SPI.The T48 and T56 has it built-in.
It is recommended to desolder the chip and use an adapter board or socket."
So please let me know why you ask me the serial number? it is possible to generate a new bios dump with it?
Really thanksLeave a comment:
It is recommended to desolder the chip and use an adapter board or socket."Last edited by volinakis; 08-02-2024, 03:46 AM.Leave a comment:
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by fulaphexhello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....-
This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 04:10 PM
This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 03:30 PM
- Loading...
