HP EliteBook 745 G6 bios
  • OKRPKCOMP
    • Dec 2020
    • 429
    • PAKISTAN
    Re: HP EliteBook 745 G6 Notebook PC
    Hello Masters
    Need repair and clean bios HP EliteBook 745 G6 Notebook PC
    board code: TINJIN-6050A3044201-MB-A01 (A1) HSN-I31C
    SN 5CG0195NLR
    bios backup attached here
    Ram section is looking good, but when turn on, always ram beeps
  • jaisharma7464
    • Mar 2023
    • 6
    • india
    please unlock hp 745 g6 bios
    • rex98
      • Feb 2023
      • 1236
      • Mandaue CEBU, Philippines
      Serial?
        • 20304
        • Zilicon
          • Nov 2020
          • 140
          • Nigeria
          please help, I need the above BIOS.
          the serial number is 5CG015F4VV
          I mistakenly lost the backup.
          Background information:
          The laptop plug-in light flashes orange and white with the power button light. Immediately they stopped flashing the fan kicks off but no display.
          I noticed there was RAM and CPU voltage when it was flashing, immediately the fan kicked off at top speed, the RAM and CPU voltages disappeared.
          I noticed that the NFC chip and the Sound IC got burnt. So I disabled the NFC unit and the Sound IC was replaced, but the behavior persists.
          There was no short on the motherboard.
          I decided to deal with the BIOS as the next step of my diagnosis
            • 20304
            How did you manage to mistakenly lost the backup
            • Zilicon
              • Nov 2020
              • 140
              • Nigeria
              I thought I did I have seen it. I will upload it ASAP.
              what happened was that I worked on multiple BIOS chip, So I mistakenly wiped the one for the elitebook. just searched for the backup that I made with everything app
              • Zilicon
                • Nov 2020
                • 140
                • Nigeria
                Attached is the backup. Thanks a lot.
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                • Guest
                  Elitebook 850 G5 BIOS bricked
                  by Guest
                  I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                  I assume the BIOS update failed, so I searched for the BIOS chip.
                  I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                  However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                  Can the corrupted...
                  03-24-2025, 01:21 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • ktmmotocross
                  Old hp compaq nc6320 weird beeps after low bios battery
                  by ktmmotocross
                  Hello.
                  Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
                  i attach record of beeps...
                  04-27-2025, 12:48 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
