Bios HP Omen 17-an107ng G3BE N17
  • Stevens02
    • Jun 2023
    • 19
    • Austria
    Hello everyone!
    I need a Bios for an HP Omen 17-an107ng G3BE N17
    Thank you so much!!
    • 20818
    Re: Bios HP Omen 17-an107ng G3BE N17
    Originally posted by Stevens02
    Hello everyone!
    Thank you so much!!
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
    • Stevens02
      • Jun 2023
      • 19
      • Austria
      Quanta DAG3BEMBCD0 Rev D
      • Stevens02
        • Jun 2023
        • 19
        • Austria
        The Sticker on it
        • Stevens02
          • Jun 2023
          • 19
          • Austria
          The Problem was Power Rail not Present,PCH defekt,Mosfets burnt Layer restored,when i insert the charger now Orange light is Present,Battery load ok turns in White light.When i Press the Power Button,Power light begins to flash but wont start
            • 20818
            When a PCH is changed the ME firmware must be cleaned ,we have some guides if you want to do that yourself https://www.badcaps.net/forum/showpo...41&postcount=3
            Post your bios backup if you can`t do it. Where did the PCH chip come from,was it from a donor board
            • Stevens02
              • Jun 2023
              • 19
              • Austria
              Hello and thank you!!
              The PCH was a new one.I have no experience with ME cleaning so i send the Original Bios Bin.
              Hope you can help me.
              • Stevens02
                • Jun 2023
                • 19
                • Austria
                I zipped it so it should work
                  • 20818
                  You havn`t made a good backup
                  https://www.badcaps.net/forum/showpo...40&postcount=2
                  Originally posted by piernov
                  When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                  On Windows, you can use the command "fc /b" to check if two dumps are identical.
                  Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                  • Stevens02
                    • Jun 2023
                    • 19
                    • Austria
                    Originally posted by SMDFlea
                    Thank you,the Problem is after reading the chip and Verify Data i erased it and try to Flash a Bios from the Manufacturer Site.
                    What can i do in that case?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11713
                      You have to restore the DMI and windows key yourself because the original bios is no longer there.
                      • Stevens02
                        • Jun 2023
                        • 19
                        • Austria
                        What is the DMI and how to restore both?
                        • Stevens02
                          • Jun 2023
                          • 19
                          • Austria
                          Programmer Error File Size Larger than IC Size.
                          I dont know how i should solve this Problem
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11713
                            DMI is all information about your device such as serial number, product,...
                            • Stevens02
                              • Jun 2023
                              • 19
                              • Austria
                              Thank you but i have no experience in Bios Modification.
                              The Problem is the Bios File is to large to Flash,and my old Bios is erased.
                              I have no Idea whow i should solve this Problem.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11713
                                What ? The file is only 16MB, which chip did you read from?
                                • Stevens02
                                  • Jun 2023
                                  • 19
                                  • Austria
                                  OMG I Focused on the false Chip,i found the right one.
                                  • Stevens02
                                    • Jun 2023
                                    • 19
                                    • Austria
                                    i must buy a 1,8V Adapter before i can continue
                                    Hope SMD Flea can now help me with CleanME
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11713
                                      Wrong chip or fault backup, You need to find a 16MB chip: 25Q128...
                                      • Stevens02
                                        • Jun 2023
                                        • 19
                                        • Austria
                                        Hello
                                        I finally managed to read the bios.
                                        Attached I am sending the files. Please can someone help me with Clean Me (PCH swapped, no boot)
                                        • JoWed
                                          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                          by JoWed
                                          Hello Community,
                                          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                          07-01-2025, 09:32 AM
                                        • Dani Rahal
                                          hp omen 17-cb0247ng bios
                                          by Dani Rahal
                                          Hi can some one help me plz
                                          i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                                          i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                                          the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                                          i have the orginal bios if some one can see what the problem or...
                                          05-30-2025, 09:11 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zerbatin
                                          HP Omen 16-c0825no BIOS.
                                          by zerbatin
                                          I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
                                          I have tried using this DUMP but with no go,
                                          https://www.badcaps.net/forum/troubl...os#post3210916
                                          My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
                                          07-17-2025, 02:14 PM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
