bios samsung NP930XDB
  • phamduy221
    • Jan 2021
    • 54
    • vietnam
    Hey guys I need a bios bin for this samsung NP930XDB laptop. Thank you
    machine name: samsung NP930XDB
    mainboard code: BA41-02882B
    S/N: 5CB79FHT100036E
    The original BIOS seems to be corrupted, so uploading it may help
  • minhdigital
    • Nov 2022
    • 758
    • Vietnam
    Re: bios samsung NP930XDB
    Send to you, try test and feedback !!
    • Mrav1337
      • May 2016
      • 10
      • Croatia
      Samsung NP930XDB-KD1SE
      S/N : 4WX39FHRB00275P
      Hello. I need someone to help me with making new bios from bios update file. I have attached old corrupted dump.
      I have tried to follow the guide on youtube but I stuck in editing and merging the info from old bios in the hex editor after I sucessfuly extracted the bios with AMI_PFAT_EXTRACTOR.
      Can someone expirienced help me make finished bin file so I can try to fix this laptop.
      I have tried some files I found here but I had no luck and I reverted the laptop to the old bios.
        SMDFlea commented
        Editing a comment
        thread merged.
    • Mrav1337
      • May 2016
      • 10
      • Croatia
      I have tried this one before opening this thread and sadly it doesen't work for me.
      • volinakis
        • Jan 2021
        • 2743
        • N/A
        you didn't "sucessfuly extracted the bios", as you can see the length of bios backup and extracted file are different. In the file extracted there is only Bios_Region (among other sh*t) and not ME_Region as well. try this file.
        • Mrav1337
          • May 2016
          • 10
          • Croatia
          Unfortunately it doesent work. I have attached original bios update file from Sasmung website before I have extracted it with find_gz125. If you can make something out of it that would be great, if not thank you so much anyways.
          • volinakis
            • Jan 2021
            • 2743
            • N/A
            try this one
            • phamduy221
              • Jan 2021
              • 54
              • vietnam
              I have tried bios #2 and it's good, can you check if the main code is correct? If it's correct, the problem is not the bios
              • Mrav1337
                • May 2016
                • 10
                • Croatia
                try this one
                Its the same. I guess problem lies somewhere else. It powers up for 3 sec then shuts itself down. Everything started after bios update through windows update.
                With the dump corrupted bios in first thread i get samsung logo at least for 1 sec before shutdown. Thank you for help.
                • Mrav1337
                  • May 2016
                  • 10
                  • Croatia
                  If I reconnect the battery and then I open the laptop lid it turns itself up for 3 seconds, keyboard lights up and I get Samsung logo up and for the moment it goes to windows for split secont and shuts itself down.
                  I can even enter the bios in that 3 seconds but it shuts down again.
                  After that I cannot turn the laptop on no matter what. Power button doesent do anything. I have tried disconecting and reconecting everything I can.
                  Only way I can turn it on again is reconnecting the battery. It only boots on opening the lid, not on power button.
                  All of these are with original bios dump. With every other bios I tried here, laptop turns on the keyboard lights but I get nothing on display, only black screen.
                  • phamduy221
                    • Jan 2021
                    • 54
                    • vietnam
                    My original bios #1 still works, the mainboard has a cpu error and I replaced it and bios #2 comes up fast
                    • volinakis
                      • Jan 2021
                      • 2743
                      • N/A
                      try clean ME bios without Bios_rgn replaced. And check soldering, it's impossible that if it is a bios problem none of images here isn't working.
                      • volinakis
                        • Jan 2021
                        • 2743
                        • N/A
                        Click image for larger version  Name:	dataurl001339.png Views:	0 Size:	359 Bytes ID:	3473371
                        bios image from post 2 is not working for his laptop, there are 2 ME firmwares 15.0.35.1951 Con_LP_B_Prod_Extr
                        • Mrav1337
                          • May 2016
                          • 10
                          • Croatia
                          Guys thank you so much but unfortunately this changes nothing. I guess in the end that some of your uploads should work but it is not the case here. Only with original dump laptop shows image for 3 seconds, so I guess problem lies somewhere else and not the bios image.
                          • Kjell
                            Samsung Series 9 - BIOS issue
                            by Kjell
                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                            08-01-2025, 09:15 AM
                          • FalconPunch
                            Surface Pro X 1876 Bios corrupted
                            by FalconPunch
                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                            08-09-2025, 03:56 AM
                            Samsung Galaxy Book Pro NP930XDB-KH1SE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP930XDB-KH1SE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XDB-KH1SE boardview and NP930XDB-KH1SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 03:10 AM
                            Samsung Galaxy Book Pro NP930XDB-KH2SE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP930XDB-KH2SE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XDB-KH2SE boardview and NP930XDB-KH2SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            Samsung Galaxy Book Pro NP930XDB-KF6IT Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Pro NP930XDB-KF6IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XDB-KF6IT boardview and NP930XDB-KF6IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 02:50 AM
